Question about Toysmith Mini Mars Mud
How do I get mars mud out of my carpet?? It has dried hard.
Get mars mud out of clothes
Use Rubbing Alcohol (70% Isopropyl Alcohol) from the drugstore. It is the easiest way to remove Mars Putty from natural fabrics and hair.Do a spot test first on a non-visible part of fabric to ensure the alcohol will not cause further damage. Liberally pour the rubbing alcohol onto the affected area. The Mars Putty should liquefy and become easily removed with a paper or cloth towel.
If your Mars Putty has adhered to a synthetic fabric such as nylon or polyester, Rubbing Alcohol may damage the fabric. Try WD-40 to loosen the Mars Putty and remove it from the surface.
If all else fails, take your garment to the dry cleaners and let them know your stain is silicone based.
Jun 15, 2014 | Toysmith Mini Mars Mud
Tip
Offroad mud cleaning
in case you go offroad and get lots of mud
it is very importanat to clean it good and not to let it dry, other wise it will be hard to get off
on Apr 13, 2010 | Jeep CJ Cars & Trucks
Mars mud is dried out. how do i make gooey again?
Put some water in it/on it and hit it whith a spoon and start mushing it
Jul 29, 2011 | Toys
I have a 2005 Altima and there is a leak in the front passenger side under the carpet. Terrible mold smell. We've pulled the carpet back and the jute is soaked. Any idea where the water could be coming...
1) Check the pollen filter, its probably in a poor state if its not been changed yet.
2) Check the bulk head drains.
3) Check the sun roof drain pipes (usually run from under the sun roof, down the door pillars to the wheel arches, often covered by an plastic inner wing) clear out all the mud and debris.
Apr 13, 2011 | 2005 Nissan Altima
Air conditioner works good.but water leaks back into carpet on passongerside dash.ruins carpet and smells.any help appreciated.
There is a drain hose that is probably plugged. Under the hood, but close to infront of the passengers feet. It's low and a little hard to find, but a good chance it has mud or dirt in it.
Mar 18, 2011 | 2004 Oldsmobile Alero
My granddaughter got Play Doh in the carpet. It looked like it was mashed in the carpet. How do I get it out without ruining the beige carpet????? souder.m@sbcglobal.net
Just leave it alone and allow it to dry. When it dries out, it becomes hard you can break it up into small pieces using a stiff brush. Then you should be able to vacuum it up the dried out pieces. Hope this helps you.
Mar 09, 2011 | Play Doh Toys
Mud mud mud, rain rain rain how to dry mud up? new home construction. put crush and run in drivway pure mud has swallowed 1st and second load of crush and run, had 9 inches of snow saturday, more expected...
depending on what the ground looks like under the surface stone dust might work well to help fortify the top layer into a solid mass. where are you in?if the grounds going to freeze i wouldnt do anything now.
Feb 04, 2010 | Sport & Outdoor - Others
Bissell Pro Dry will not turn on.
it's either the motor blew or something in the motor popped out of place, I have the same steamvac and it has done that before. Take it into a vacuum shop
Sep 11, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Hose not picking up
Hi MightyHeidi,
About once every 9 months to a year, I have to take the hole Cleanview apart and thoroughly clean filters and get all the trash and string from the roller Brush.  I was the cleanview buckets out and rinse the filters untill i get no more mud flowing.  ThenI let it dry for a day or two. Put it all back together.  About once every 3 years, you may want to do a full disassembly to get to the Check valve at the intake of the Blower Motor.  i found mine stuck open and causing me to loose vacuum.
Sep 01, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Toysmith Mini Mars Mud Logo
522 people viewed this question
Top Toysmith Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toysmith Toy Expert? Answer questions, earn points and help others
