Question about Kenmore Washing Machines
Kenmore 400 series washer. Only three years old. Worked fine until last week, it wouldn't restart after I had paused it. It blew the circuit breaker, shorted the socket, and continues to trip the breaker every time it is plugged in.
    President:
  • 1,654 Answers
There is a dead short somewhere in the unit, I suspect a leaking pump and the motor got wet, is there any water under the unit? If not then you will have to remove the cabinet and check from the power cord to the control panel and beyound if neccesary to find out what is causing the short. Does the unit trip immediatly or does it take a while. If it takes a while and you have power to the unit for a little while then you may have a motor that is weak and stuck in a bad spot on the winding, you can try to spin it a small distance to see it it will take off. But BY All Means, UNPLUG THE UNIT BEFORE OPENING THE CABINET! These newer machine the cabinet slides off towards the front after you remove a few screws holding the control panel on.
Posted on Mar 26, 2011
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
How many years should a top load washer last?
Depends on how often you use and maintain it. I worked on a 1967 Lady Kenmore last week that is working just fine after 45 years.
Oct 31, 2012 | KitchenAid KAWS700L Top Load Washer
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
Kenmore Series 80 agitate for 10 seconds and pause for several minutes
No, the most is a damaged pump, does it pause in agitation or just spin? I would check the lid switch and timer.
Oct 12, 2008 | Washing Machines
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Washer pauses at various points in all cycles
Peace friend,
ngfam1 at your service
Tell the dealer you want a different make!
IT'S EASIER TO KEEP CUSTOMERS THAN TO FINED NEW ONES!
We have been selling appliances for over 65 years!
And you will only see one GE appliance on my showroom floor!
Whirlpool or SPEED QUEEN! ARE THE BEST!
HERE IS MY STORY FOR YOU!
AFTER 6 YEARS AND THREE repairs.
I threw GE in the trash and bought a Speed Queen Commercial grade washer and, I AM 53 YEARS OLD AND THIS IS THE LAST WASHER I WILL EVER BUY!
tHEY ARE TESTED AT 8 loads a week for 25 years!!!!!!!
The washers and dryers today use so much less water,electricity,and detergent that they pay for them selves after a only a few years.
My advise is, it is cheaper to buy, run, and operate a new efficient machine! You will see you water and electric bill reduced!!!!!!!!!
Speed Queen commercial grade top loader uses only 34 gallon of water compared to the others at 48-54 gallons!
THE FRONT LOADER,
(GET THIS) ONLY 13.9 GALLONS of water and washes in 35 minutes and the clothes are cleaner and last longer cause it uses water agitation instead of a vain to wear out your clothes! How about spinning at 1000 RPM and the clothes come out so dry they are only in the dryer half the time than all the other machines! Thus half the gas or electric bill!!
All my employees have replaced their laundry pairs with Speed Queen!
My Guys call it the, "No brainier Machine!"
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Aug 31, 2008 | GE WCVH6260F Front Load Washer
Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
167 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
