Question about Peavey SP4 2-Way PA Cabinet (2000 Watts, 2x15 in.)
Crossover blow drivers.How can i get the part for thecrossover that has copper wire wraped on a piece of metal.What's it called? a coil or what.All i know is it keep the driver playing and keeps it from being blown
    Scholar:
  • 150 Answers
Hello iwelch1194:
The thing you are describing is called a choke or a ferrite crossover coil.
This site might have what your looking for:
"CLICK HERE"
That is there ferrite page. If you need something a little different just search their site. You will also need to know the COIL VALUE and wire size which should be labeled on your old coil in order to replace it with something compatible. Coils are rated in millihenrys (mH).
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Posted on Mar 26, 2011
Where is the output IC on a Peavey Max 115? I've been researching away, and I'm still stumped.
You might thy going backwards from the output to the IC .have a good light and make yourself a pointer that is nonmetallic which you can track the copper strips on the circuit board without touching them. If you remove this IC from the board, be sure to wear a grounding strap to your hand or wrist, connected to the metal chassis.BE SURE TO REMOVE THE POWER CABLE BEFORE YOU BEGIN! Note the exact way you remove it. The number one pin will have a indented dot on the plastic case. Be sure to reinstall in the correct order. ALWAYS WEAR A GROUNDING STRAP TO HANDLE ANY IC! The static electric in your body can blow certain IC units. You can make you own grounding strap using an old metal watch band, a piece of flexible wire approx. two feet long and an alligator clip to attach it to the chassis. Hope this helps you and I hope I have not confused you.
Nov 03, 2017 | Peavey Music
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
I just bought a used Fender Stratacoustic, and it has a bad ground, (while plugged in of course). If I touch the metal piece on the end of the cable that it is plugged into, all ground noise stops. Is...
Taylor make a factory solution for this issue- you basically need a metal strip located where the ball ends of the strings anchor, and a wire running from that to the ground on the output jack. The Taylor piece is about 25.00, but is only good for pins that are in a straight line, not the "vee" shape of some of the Stratacoustics. I have made my own version through the years, using thin piece of metal, holes drilled to match the alignment of the bridge pin holes, held inside in line with the bridge pin holes by two-faced carpet tape (the thin kind)...with a wire soldered to it that is then run to the ground tab on the output jack. Then any time you touch the strings, you ground the guitar. This is usually a problem caused by the ground attachment on the under-saddle pickup, btw, right where the wire joins the pickup under the saddle.
Sep 02, 2013 | Fender Musical Instruments Corporation...
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
Why did my Behringer b212d horn stop working.
The problem is bad high freq. IC TDA7293.
There is no pasive crossover.
Nov 30, 2012 | Behringer B212D Powered Speaker (550...
My pair of Peavy 118 unpowered subs quit working simultaneously. There was not any horrible noise or anything like that. They simply stopped working. I have a crossover and a biamped system that they...
I would NOT rewire them. The crossover is also part of the protection. The big question are the speakers themselves damaged? There may be a protection fues inside. There are also some resetable type fuses called "polyfuse" that sometimes fry and require replacement. This speaker is rated at 800 watts PEAK and 400 Watts program... that is NOT 400 watts continuous RMS... it is "specsmanship". You should be driving this with an amp capable of NOT MORE than 300 Watts.
They claim a SPL of 118 Db. That is loud, but if you used an amp capable of say 500 watts RMS you could easily blow the speaker. The crossover for this is likely a simple coil in series... possibly on a ferrite core. Hopefully if anything blew, it was the coil... but that is NOT likely. I assumed you have checked the amp as that would be the MOST probablle for a simultaneous failure of the subs.
May 14, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
jimmydsmith@cox.net
Phoenix, Az
Jan 09, 2009 | Music
Peavey SP4 2-Way PA Cabinet (2000 Watts, 2x15 in.) Logo
149 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Peavey Music Expert? Answer questions, earn points and help others
