Question about Philips PET702 Portable DVD Player
No video hi , i just trying to connect my FTA(from DishNetwork) to the A/V slot , i have audio but no video appears , any solution ? thank you
In the control remoto press display key and your problem it,s over
Posted on Mar 06, 2009
I'm trying to connect my slingbox connection to my dishnetwork box. It is currently connected to my modem and all lights are on. I changed my modem since getting my slingbox, so my security info has c
Hi Linda,
Here are somethings to try. You should not have this problem if you have cable internet. If you have DSL service make sure the modem is in bridge mode, next make sure the settings are MTU enabled and finally place your setting to 1492. If you need further assistance please email with all information on yor set up and the DISH Network account number.
Thank You
Mark Haakenson
Internet Response Team
DISH Network LLC
mark.haakenson@dishnetwork.com
Nov 20, 2011 | Sling Media SL150-100 Network Adapter
The problem of my camera is that no sound appear when i record a video..how can i solve this problem,thanks.
Hi music_divina ,
This could be due to the fact that you have a digital camera without an inbuilt microphone in it.
Usually camcorders do have in built microphone so that you can record sound as well as video simultaneously, whereas digital cameras are meant for high quality pictures , rather than videos.
So if you want to record good quality video along with audio , I would recommend you to get a camcorder.
If you have a webcam and you want to record audio along with video , then you can easily do it by using the microphone which is to be inserted in the mic slot just besides the speaker's slot with a microphone icon near it.
All you need to do is select the video recording source as your webcam and audio recording source as your microphone and there you go , you have the recording with audio.
Hope this helps ...:)
May 11, 2011 | GE Cameras
I am hooking this unit up to a fairly new TV. and I have plugged in the AV cables to the TV from the DVD unit, though I only have the red green and blue cables and tyhere appears to be 6 slots, and I get...
If you have only connected red green and blue (component) plugs, you will have no audio as these 3 plugs are all for video and all are required or you will get a black and white picture.
You currently have 3 spare slots/sockets. You need to connect another RCA type audio cable (2 plugs - red and white) from the left and right audio out sockets on the DVD player to the left and right audio in sockets on the TV. Do not disconnect any of the red, green and blue plugs to use for the audio connection!
Red is normally right and white is left, but it doesn't matter which round you connect them as long as you connect right to right and left to left. The yellow socket is for composite video so make sure you don't connect either of the audio cables to this socket or you will get mono sound.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | JVC TH-C30 System
Random HDMI audio and video drop out & video noise
Hello, I am sorry about your issue. I suggest that your receiver be looked at by a service center. Thank you. Onkyo USA
Apr 03, 2017 | Onkyo TX-SR606 Receiver
ECS 945P-A (V3.0) no video?
hi im josh in cebu phils. may i help you? friend the problem focus in your video card or video connections . Try to check first the connections if nothing is been cut or not properply inserted or loosen. then if no effect go to the video card slot. try to tighten firmly the video card from the slot.clean the slot or transfer another clean slot. then turn on your pc. Good luck.hope i helped you.
Feb 20, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Out Put on Television
First thing you have to change which monitor is the main monitor it can only play the video on one monitor at a time depending on your video settings. Secondly with audio you will need a 3.5mm to RCA/composite audio cable to get sound on your tv. Enjoy and please take a moment to rate my solution Fixya.
Thanks,
Lee
Dec 05, 2008 | HP Compaq Evo n610c Notebook
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
Philips PET702 Portable DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
