Question about GE Profile JS968SFSS Electric Kitchen Range
I try to set oven temperature, and it shows "LOC"
5 Suggested Answers
  • 21 Answers
SOURCE: Oven not about 100 deg. below temperature setting
It's easier to eliminate the element.You can do this two ways;first thing,remove power from unit.Unplug it and you know for sure power is off.Inside the oven you can get to the wiring on element by removing the two screws on the back wall that holds the bracket to the wall.(this works for both elements)Pull the element out and you will see the wires(2).They will be either screwed on or connected with spade clips which pull on/off.Remove at least one wire and use your meter,set on ohms, put a meter lead on each element connector,you should read continuity.If you don't the element is bad,replace it.Give the elements a good visual inspection first,some times you can see where the element burnt out.The other way to get to the wiring by pulling the back panel off the stove.Hope this helps. Gregg
Posted on May 29, 2009
SOURCE: The F1 code appears in the digital temperature of the oven
This is for a Whirlpool F1 code, but that code means the same on virtually all brands. Try this:
You have either a bad ERC (clock) or a bad touch pad. Here is the procedure for determining your problem.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for codes and listen for the beep.
  7. If you get a code and beep, replace the ERC.
  8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Posted on Feb 21, 2010
arepairman
  • 20 Answers
SOURCE: The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Posted on Mar 14, 2010
  • 2468 Answers
SOURCE: take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Posted on Jun 18, 2012
I tried to press bake which turns the oven on usually and got LOC in white letters instead of a temperature
Perhaps indicating the oven door is locked.
Look for an unlock button.
my Fridgaire oven has a led to indicate door lock
Nov 13, 2016 | Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Take GE Profile Oven LOC from pannel
Jun 17, 2012 | GE Ovens
Kenmore Electric Oven won't bake after using self-clean!
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort. Now comes the bad news, you fall under the catagory of damaged electronics. The control has been damaged and I wouldn't doubt if the sensor as well.The part number for the control is WB50T10056 and cost about 108.20. The sensor part number is going to be WB21X5301 and cost about 94.00 On the second part I would call my local parts distributor and as if there is a sub part for it and self yourself about 50 bucks or so. Sorry, and good luck.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Kenmore Ovens
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
Ican't turn the oven on. When I press "Bake" it goes to LOC and then turns itself off. I should be able to adust the temperature (+ or -), then press start.
Hi
If it is a GE oven then you can try and reset the LOC error by pressing 9 and the 0 simultaneously for 5 seconds or until the LOC disappears. Alternatively you can try pressing the "Oven Lockout" or "Range Lockout" button on the control panel and then the "Start" button. Hope this helps... Please post back with make and model# of your Oven if you need more information.
Daniel
Nov 10, 2010 | Ovens
GE Profile JS968SFSS Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
