P.E means Pressure Switch error. Either the small pipe is clogged or the Pressure Switch is faulty.
Check the following on the Pressure Switch:
- Clogged Pipe?
- Loose connections on Pressure Switch?
If these are fine, and it is giving you the same problem, then I'd suggest replacing the pressure switch. It is not an expensive part at all. See attached pictue of a Pressure Switch example.
Hope it helps :-)
* A Four Thumbs up and a neat Testimonial if this helped you
