Question about Kitchen Ranges
Kenmore 790 range conversion
I have a model 790.78733406 gas range that has been converted to LP. I lost the instructions in a recent move (although I didn't do the conversion in the first place) and need to convert the oven burner\broiler back to natural gas. The stove top isn't a problem, just oven.
SOURCE: changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Posted on Nov 22, 2007
SOURCE: LP Conversion Kit?
I'm looking for the same thing! My kitchen is covered in black soot and the inside of my new oven is BLACK!!!
Posted on Jan 06, 2008
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: Converting Kenmore gas range to LP???
I had success with the conversion. The directions are very cryptic, but it can be done, without the professional emptying your wallet, for 5 minutes worth of work. No adjustments needed on the air shutters, once they are wide open. The orifices are the pain-in-the-a$$es. You need some small tools to get to them, or chance dropping them under the top....which wasn't fun. Oh...and watch which orifice goes where...there are 3 sizes. So, short version, change orifices, open shutters, and flip regulator setting from NG to LG. Orifices take the longest time. ~ sjDIY
Posted on Oct 31, 2008
TheMobilian
  • 8220 Answers
SOURCE: Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Posted on Dec 15, 2008
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
How do I convert a kenmore gas range model 790 back to natural gas from lp?
You don't need to change the regulator, just the orifices.
Sep 09, 2015 | Kenmore Kitchen Ranges
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
I need to find a conversion kit for my kenmore 790 range to switch from propane to natural gas. Where do i find it?
Most Kenmore ranges ship with the NG to LP conversion kit attached to the range. The conversion kit and instructions are in a bag and should be tied to the back near the regulator or behind the storage drawer. The installer who did the conversion was supposed to put the kit back with the original orifices in the bag.
If you do not have the kit, try looking for the manual at http://www.managemyhome.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu and ordering the conversion kit from http://www.searspartsdirect.com/ .
I hope this helps.
Aug 26, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
How do i convert my 790.71011200 kenmore range from natural gas to LP?
After looking high and low for a conversion kit I finally looked up the installation manual for your range. AND gues what!! you have everything you need there!! Just follow the instructions in the installation manual for conversion over to LP.
Download the installation manual here if you do not have yours. The instructions are in the back pages 9 & 10.
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0207026.pdf
Have fun!!
Heatman101
Jan 19, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight!
Alright...got it out of my system...here we go:
1. Find out if a conversion kit exists. Answer: Yes it does...in fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
http://www.fixya.com/support/p106248-kitchenaid_kgsa906pss_gas_kitchen_range/manual-13680/page-7
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I cannot seem to get an answer from Amana as to how I convert my natural gas range to LP. According to Amana no conversion kit is needed. Yet they cannot tell me how to convert it. The model number is:...
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
Dec 24, 2008 | Amana AGR5735QDS Gas Kitchen Range
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
