Question about Whirlpool 3.2 cu. ft. Washer
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
  • sir_tommis Mar 26, 2011
    I have tried this salution and it did not work sorry that is why I wanted to ask more people
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If you are using "soap powder" in your machine then you have soap buildup under the agitator and likely under the wash basket also. If you will post the model number that is on your machine, I will be able to tell you how to remove the agitator and basket so you will be able to clean out any buildup.
Posted on Mar 26, 2011
  • Charnelle Gray Oct 27, 2011
    Hi I have the same problem with my Samsung toploader model WA13G7Q1 can you help me please
    Guru:
  • 257 Answers
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing FixYa.com
Justin
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I have model 110.60832990 and the dryer is on the drum is turning, the heat is on but the clothes are not drying.
Check the air outlet and see it is not clogged with dirt/flint. Clean the air filter mesh located at the air outlet of flint. This blocks the free flow of air and thus do not dry the clothes. Drying will take place when the air inside has free flow. Before putting clothes in the dryer EVERYTIME this filter must be cleaned OR after every drying cycle.
Aug 29, 2010 | Dryers
LAUNDRY SMELLS BAD
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
Dec 30, 2009 | Bosch WFL 2063 Front Load Washer
When I print in colour there is a white streak from top to bottom about 5 cm from the left hand side
- remove all cartridges
- clean all leaked powder on the cartrtidges and inside the 4 cartridge compartiments with a vacuum cleaner
(don't touch the powdered roll on the cartridge!)
- deep inside the printer you will see a glass-strip. You have to clean this strip carefully. Because of powder, that has leaked from the cartridges, the laser-beam is dimmed. This causes the white streak you mentioned!
Oct 04, 2009 | Konica Minolta magicolor 2430 DL Laser...
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
White powder coming from dehumidifer.
Commercially available cool mist humidifiers sonicate water in order to create a fine mist. In other words, intense vibration liberates millions of tiny droplets of water from the reservoir. This water contains all of the salts of the original tap water. Consequently, over time, you will begin noticing that a fine white powder covers EVERYTHING in the room. This is the same stuff that is trapped in the reservoir of a warm mist humidifier.
its harmful but very annoying !
please rate me
May 29, 2009 | Maytag M7DH65B2A Dehumidifier
WATER LEAKING FROM POWDER TRAY AND AROUND DOOR
There is a ball return valve that wants cleaning. Disconnect the appliance from water and mains. Turn machine on its side and look underneath. At the bottom of the white plastic drum you should see a black rubber hose about the size of a mug fastened by a hose clip. Remove hose clip and extract the hose from the drum and look inside. You should see a white plastic cone about the size of a paper cup with a plastic ball inside, remove and clean of any debris and replace. Be careful when reattaching the black how to the drum or you will get a flood if not properly attached.
Hopefuly that will solve your problem.
Apr 27, 2009 | Washing Machines
How do I replace the Cleaning Brush for the drum?????
why in the world are you replaceing the brush? In 25 years of copiers, i,ve never had to replce a brush. If its streaking on the copy, its the blade thats bad. only reason to replace a brush is if its broke,cause of a clog. just vacumm it out.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Whirlpool 3.2 cu. ft. Washer Logo
244 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
