Question about Scosche Industries SCOSCHE GM22SR 2006UP GM LAN STEREO REPLACEMENT INTERFACE NON ONSTAR
Have red (ignition terminal) wire and yellow (constant 12v) wire that do not work into this harness. Have no power to radio
  • 902 Answers
Did you check all the fuses yo may have accidenly blown a fuse
Posted on Mar 26, 2011
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 02, 2011 | Hyundai Motor 2003 Elantra
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Need to determine whichcolor wires are for the speakers,the constant,switched.
Your vehicle radio color codes below;
Radio 12v blue + radio harness
Radio Ground (chassis)
Radio Ignition pink + radio harness
Radio Illumination yellow/red + radio harness
Factory Amp Turn-on blue/white or pink + radio harness
Power Antenna N/A
LF Speaker +/- purple - green/yellow +,- radio harness or amp under rear deck
RF Speaker +/- brown - brown/white +,- radio harness or amp under rear deck
LR Speaker +/- orange - black/pink +,- radio harness
Notes: On vehicles with premium audio systems, the LR speaker wires are yellow/green - white/orange.
RR Speaker +/- gray - gray/red +,- radio harness
Notes: On vehicles with premium audio systems, the RR speaker wires are red/black - gray/blue.
Feb 06, 2011 | 2007 Nissan Sentra 2.0 SL Sedan
I install a radio it dont keep a memory
Pull the radio back out. I bet you hooked up both power wires (red and orange or yellow) to the ignition on hot wire. Orange or yellow depending on the radio usualy goes to the ignition on hot wire and red to a constant hot wire. Check the radio wiring diagram or list. One of the power wires has to go to a full time power source. check the wires with a circuit tester with the key off till you find the constant hot wire (battery power)
Dec 17, 2009 | Kenwood KDC-MP228 CD Player
1995 toyota tacoma stereo installation - yellow 12v wire and red power wire - where do I connect these? Original radio was removed by previous owner. Factory connector cut but I have all wire showing. I...
Yellow (module memory) 12v wire needs constant power... any "always on" circuit in your car. Red power wire can be connected to your AUX fuse on your fuse panel.... or to the red power lead that powers your original radio.
Oct 12, 2009 | Pioneer CDJ-1000 CD Player
Toyota tacoma 2007 stereo wiring Colors for the following wires: Power-ignition Ground
Radio 12v blue/yellow + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- pink - purple +,- radio harness or amplifier
RF Speaker +/- lt. green - blue +,- radio harness or amplifier
LR Speaker +/- black - yellow +,- radio harness or amplifier
RR Speaker +/- red - white +,- radio harness or amplifier
Notes: If equipped, the amplifier is on the passenger side rear cabin wall.
Sep 13, 2009 | 2007 Toyota Tacoma
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Jvc car audio KD-PDR51installation problem
Your switched ignition lead is hooked to a constant voltage wire.
You need to find a source wire that is only given power with the key in the on position.
One wire (yellow) on radio goes to a power wire with +12V constant power (regardless of key position)
The other wire (RED) on radio will need to be attached to a Power wire whose supply is only +12V when the ignition is enabled.
Since you are using a wire harness, you just need to reverse the 2 wires as they currently are installed.
Hope this solves one problem anyway.
the wires being reversed on the harness also may not activate an internal relay allowing the steering wheel functions to operate.Switch the 2 power wires, and re-try.
If the steering wheel controls still fail to operate properly, your module may be defective.
Post your results.
Jan 15, 2009 | Car Audio & Video
Scosche Industries SCOSCHE GM22SR 2006UP GM LAN STEREO REPLACEMENT INTERFACE NON ONSTAR Logo
180 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
