Question about Gateway Computers & Internet
My gateway mx laptop gets so hot you can fry an egg on it and the fan runs all the time and shuts down when its hit its hottest what can be done about this i have to shut it off or the fan will still keep running as soon as its on it starts getting hot right away like 5minutes into it
  • Gateway Master
  • 32,281 Answers
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Posted on Mar 26, 2011
Testimonial: "thankyou"
Gateway laptop keeps shutting down
If there are no apparent software failure symptoms that are causing this, my best guess would be an overheating shutdown. Many laptops will get clogged with dirt because their intake fans are on the bottom and many users place them on laps, floors, and surfaces that allow dust and dirt to be sucked in easily. These clog up the heatsink that cools the processor. The unit has safeguards that shut down the unit if the processor gets too hot. Many units can be easily cleaned, but many others require a complicated tear-down to do this.
Sep 16, 2014 | Gateway Computers & Internet
Gateway md2614u shut down
I would remove the heatsink and fan, clean the processor surfaces with methylated spirit or isopropanol, use new heatsink compound and that should fix your issue. Yes yes, heatsink pipe should get hot!
Nov 17, 2013 | Gateway MD2614u Notebook
Laptop shut down
Sounds like it is getting too hot. Does it feel real hot when it shuts down? Is the fan and power supply working well and unobstructed so they get good air circulation?
Shuts down unexpectingly when running game programs
Is the Laptop Overheating? During intense game play your Laptop will Overheat if it's not getting sufficient air flow. Try cleaning the Fan, vents, heatsing with Compressed Air, Improve air flow through the Laptop, a Laptop Cooler is a option. Try shutting down unnecessary processes, I use freeware RAZER GAME BOOSTER, you configure what you want to shut down: http://www.razerzone.com/gamebooster Remember, Your machine usually shuts down for a good reason, it's trying to protect vital components. Overheating will fry the CPU, Graphics Adapter, etc.
May 11, 2013 | Gateway NV73A17u Laptop
HP DV7-3085DX Shut down at 120 degrees C
No solution, but that is really hot. Hot enough to start frying other components. Eventually it will.
Nov 28, 2012 | Computers & Internet
I would lkike to know if it is normal for this unit (T1625 ) to run so HOT? the fan is direct out the side and I bet I could cook an egg if i left it sitting there- I have cleaned the fan- but still
your laptop is probably very old or the system is bad
if you have warrenty you can get it serviced for the particular
reason.
if not you can spend a few dollars for it to be serviced.
Aug 25, 2012 | Gateway T-1625 Notebook
My gateway m520x will run shutt down
Sorry you are having trouble. Laptops run a little hot but I think you are right about the overheating. The cheapest fix is to get an underneath cooler from somewhere like Best Buy. They sell for around $20. To really fix the problem will require finding out why it is getting hot. Usually this is a program that is "hogging" the processor's time. There are programs available that will make your fans run faster and processor run cooler. Some are free. Some cost a lot. If the fan has stopped or slowed it needs to be replaced. If you are very patient you can attempt to replace it yourself but be aware many a laptop has died as a result of being opened improperly. My advice is take to a shop if under cooler does not help.
I hope this helps
Apr 04, 2010 | Gateway M520X PC Notebook
Fan not working and the laptop shuts down
Clean on Replace the fan. It is getting to hot w/o it and you are overheating the CPU.
Apr 02, 2009 | Gateway M6307 Notebook
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
Laptop Reboot on Startup
Do you want to sell it for parts
Oct 21, 2008 | Gateway MX6453 Notebook
Computers & Internet Logo
707 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
