Question about Baby Gear
I need new tires, maybe new wheel sets for my 8 year old double jogger!
The only tag left on it is on the back axle bar, and it say model # ZD- 200. It was manufactured in 03/00. I love my double jogger, and have used it daily since I have had it, and it still carries my two youngest! ( 3 and 1) The tires are literally threadbare! The bearings are shot, I think, may need all new wheel sets...I just cant seem to find where to purchase them! Can you help me?
Thanks so much!
  • linda loopy Jan 14, 2009
    i need new tires for the zooper stroller thanks
  • myersdarnell Feb 15, 2009
    I need new tires for the back wheels of the purple jogger, i can see the treads coming out of the tires
  • 51 Answers
You can contact Zooper directly at 1-888-742-9899 or
Posted on Aug 11, 2008
2004 pontiac grand prix gt. humming noise while driving. Louder at 25 mph or higher. Changed front passenger side hub bearings due to when turning slightly left humming quiets. I stol have humming....
I change both wheel hub bearings when one goes
Doesn't matter what stabilizer does--- the bushings need
to be done-- so you say
Maybe you replaced the wrong drive axle
Put the front tires on the back to see what happens
Nov 30, 2012 | Cars & Trucks
How to take off the rear tire on a Kawasaki Drifter 1500
1. Lay out a towel/cloth to set fender on and protect.
2. With bike on jack and raised(back tire/wheel just off ground), remove entire rear fender.
3. Unplug wire harness left side just to front of left shock after you remove screw/cover. There's a 8mm bolt just above and over. Same bolt opposite side of fender.
4. Remove the 4 (12mm) bolts holding fender bracket to rear housing (left) and swing arm rear (right). Hold it because it will tip back and bang! It's not real heavy but you do need to support it.
5. When removed set on towel/cloth you have ready.
6. Release pressure from brake caliper (push/pull on caliper) remove brake caliper and hang it by wire (coat hangers work great) so it's not dangling from hose. Do not touch or let anyone touch brake pedal.
7. Remove the brake caliper bracket bolt that goes through swingarm. Place a towel/cloth on floor beneath brake area.
8. Remove cotter key from axle nut.
9. Remove axle while holding axle on the left side with wrench. You can use a large crescent on the axle nut so you don't have to remove exhaust/muffler.
10. As you loosen, slide axle to the left till nut clears muffler.
11. Now when you can slide the axle out. Support the tire/wheel as it is heavy. Caution: As the axle slides out of the brake caliper bracket the spacer could fall and hit towel (which is why you put the towel there see? It prevents too much marring.
12, Now you have room to slide tire/wheel assembly over to right and disengage from the gearcase. Caution: There is a spacer in the center of the gearcase that sometimes falls out and sometimes stays in (most of time). Just make sure it goes back the same.
13. When you're ready for the re-install, grease the drive splines with good quality axle grease.
14 Re-install everything in the reverse order you took it apart.
15. Re- torque rear axle from the left side and hold axle nut (right side) with same large crescent you used to loosen the nut and install a new cotter pin. Doing it this way saves you having to remove the muffler.
on Feb 16, 2010 | Motorcycles
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
How do I fold my 2006 dreamer design double stroller
The older model joggers fold by separating the frame at the front wheel. Look behind the front wheel and you will see a black connection piece that disconnects the T frame. Release it and pull up/push back on the bar that goes between the seats. Once it goes flat, you can also fold this part onto itself. Please feel free to contact me if you need further guidance
Mar 20, 2010 | Dreamer Design Ditto Manhattan Twin Seat...
Dreamer Design is out of business. Where can I get parts and service now?
Hi, I have brand new soft parts including a new under basket for a ditto dreamer design double. My stroller died before I could put the replacement on and I don't know what to do with it. Let me know if your interested.
Apr 16, 2009 | Baby Gear
Baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Aug 25, 2008 | Baby Trend Expedition Double Jogger
Baby Tend Jogger model 9118A needs new wheels
Go to any Auto Parts store or Wal MArt Auto center etc. and buy a can of "Flat Fixer" and fill the tires with it. Problem solved :-)
Jul 27, 2008 | Baby Trend Expedition LE Jogger
Wheel alignment
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Mar 29, 2007 | Baby Trend Expedition Double Jogger
Baby Gear Logo
742 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
