Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
The "fit to copy" command
  • 3 more comments
  • Richard Katz Mar 26, 2011
    OK, but you are basically saying you don't have a solution, so do I have to pay for that?
    The reply link to your comment does not work.
    This is a function of the HP 8500 at the control panel on the device itself, not a computer function.
  • Richard Katz Apr 02, 2011
    It was suggested that I try attaching the printer/copier to another computer, but the function we are dealing with does not involve a computer, but is initiated from the control panel of the device. It was also suggested that I download the latest firmware, but the device already has that same firmware version. I have run out of options. The fit to page function sometimes works and sometimes not, and I can't see any consistent pattern. HP told me to do a hard re-set, but the problem re-appeared after a short while.
    Thanks for the further information. You have a good point about the electronics being affected by power outages. We've had a lot in our area lately due to many snow storms. Hopefully that's done for the year. Unlike the PC, I don't have the printer on a UPS. Maybe I should, as it's not a laser. As for it being a non-persistent command, the display will show that "fit to copy:" is selected, but then it will copy at original size. Other times the display will show "fit to copy" and it does exactly that. When I save new defaults, the "fit to copy" selection that is displayed is persistent, but the behavior is not.
    One thing I am not understanding is the relationship of the drivers on the PC to this behavior, since we are typically running the copy function not from the PC but from the device panel or copy button itself. Is that behavior affected by the PC.
    I am suspecting your insight about the electronics being damaged by the power outages is true, because it suddenly stopped responding to print commands. I solved that by uninstalling the printer and then it automatically found it again and reinstalled the drivers and it works.
    So, if the electronics in the printer are damaged, can redoing the installation on the PC actually fix that? Or do I need to get a replacement for the printer?
  • Richard Katz Apr 05, 2011
    I wonder if your experts are reading what I am writing. This is not an error in printing from the PC. This has to do only with the copy feature on the machine itself, something that can run totally independently of the PC. So reinstalling the driver is irrelevant to the "fit to copy" issue.
    I did reinstall the printer driver once when that got disconnected, but it had nothing to do with Windows XP service packs. I am running the latest.
    Genius:
  • 1,570 Answers
Hi
I suggest you repair or install the Service pack 2 or 3 of your operating system like for windows xp to correct the corrupted driver in the windows registry that change the setting from time to time.
Then uninstall and reinstall the printer driver and set up once more the printer. Check if it solves your problem.
I hope it helps you, Regards
Posted on Apr 02, 2011
  • HP Master
  • 12,061 Answers
Hi well "usually "Fit to Copy" is a NON-persistent command, meaning you must set it each and every time you wish to use it.? also are you using the Print management software that comes with the printer, that will permanently set settings whereas windows properties may not?
It also depends on what program you are printing THROUGH ? This make a difference too.
below is your user manual, in here are all the commands you will need to know.
h10032.www1.hp.com/ctg/Manual/c01643304.pdf
one reason, usually why the printers go like this is because the electronics primarily, the brain/memory areas are going/are? faulty, i have seen this many times, and slowly, all functions go awry over time, perhaps this is what is happening here too? When there is no logic or consistency to things then this is what it usually is, and the usual cause Power spikes surges, outages etc.
Really all one can do, is replace all the printer drivers again ON your machine that's VERY important must have the actual copy of the driver and software on the PC. Ensure that it is the latest. Also redo any Batch files associated too. Also, do a defragment of the HDD, do a HDD Disc cleanup too.
    Genius:
  • 1,098 Answers
Hi. I understand you frustration. To be honest with you, doing a hard reset is the last option that the unit can do. If problem went back after hard reset then there is a huge possibility that the firmware has a problem. Re-imaging the firmware would be the best solution for this issue. Only manufacturer can re-image the printer's firmware. I suggest you send the unit to HP for firmware re-imaging if it is still under warranty.
Posted on Mar 26, 2011
  • Ivy  Cada
    Ivy Cada Mar 26, 2011
    have you tried installing the printer to a different computer? try to install it to a differenet machine and see how's it going.
  • 844 Answers
Welcome to FixYa!
Good day. I have a few suggestions. I am not able to see what other experts have suggested so please bear with me if you have already done it.
1. Please check from the procedure below to make sure that you are saving the new settings properly.
To save the current settings as defaults for future jobs
  • Make any necessary changes to the settings in the COPY menu.
  • Select COPY, and then select Set New Defaults.
  • Select Yes, and then press OK.
2. Upgrade the firmware. The recent firmware upgrade release was April 28, 2010 and it fixed/enhanced the following:
  1. Improve paper pick performance
  2. Optimize the print head life
  3. Improve network connectivity
  4. Improve scan/copy/fax functionality
To download the firmware upgrade, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3752459#N307
Note: The printer needs to be connected to the computer with the basic drivers installed.
The upgrade will update the firmware of the printer itself.
I hope this helps and thank you for using FixYa!
Keep me posted.
Jas247
Error message says wrong catridge even though I know it is the correct one
Sounds like the cartridge you used is a refill and after a time the printer can read the cartridge so although its been filled and so called cleared so the machine thnks its a new one the printer reads it a duff one ,fit a new new one and iam sure it will work
Mar 20, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Tip
All about Windows SAM file
<b>Section 1 : General Information</b><br /> As you may or may not know, all of the passwords on a Windows XP computer are stored in a SAM File. This file is located on your computer's hard drive in the directory "C:WINDOWSSystem32Config" The file's name is SAM, obviously. Now, you may be thinking, "Wow, this was incredibly easy, I just right click the file, and click send to a floppy or where ever. Well, unfortunately, it isn't that simple. I will detail the various methods of getting the SAM file in the next section.<br /> <br /> <b>Section 2 : Obtaining the SAM file</b><br /> In the previous section, I discussed where the SAM file was found. As you may have found out, when you attempt to copy this file, you get a nasty error saying something along the lines of "Access is denied. File is in use." The SAM file is in use by the system, so you cannot just go to task manager, and end the process. You need to find alternate methods of starting up the computer without using the SAM file. As far as I know, this can be done several ways. <br /> <br /> Booting the computer up into Linux using a boot CD or floppy is one method. To use this method, you will need a Linux Boot CD, and access to BIOS. If you don't have access to BIOS then consult one of the many tutorials on the web on how to crack the BIOS password. <br /> <br /> To make a bootable Linux CD, you have to find a version of Linux, which can be burned and run off a CD (To find these, consult my links, or search google). This should be relatively easy to find. Next you need some kind of burning software, which allows you to burn an image onto a CD (Consult Links, or search google). This a bit harder to find for free, but a demo works just fine. After you have these, burn the image to the CD. You now have a Linux Boot CD.<br /> <br /> Now to alter the BIOS settings, so that you can boot into Linux from the CD. Shut down your computer, and during the start up screen, you should see a notice to press F1 or F8 (Maybe a different key) to enter Boot setup. Press it. This will take you into the BIOS, however, if there is a password on the BIOS, then you have to consult an article about cracking BIOS passwords. Next go to Boot Order and change the CD drive to first. Save your changes, insert your Linux CD and exit. Let the system boot up. It should boot into Linux if you did everything correctly. Now all you have to do is insert a blank floppy, and copy the SAM file to it, since it is not in use anymore because Windows is not running. Congratulations, you now have the SAM file. Be sure to get the SYSTEM file in the same directory as well, as some passwords are encrypted with keys from within that file.<br /> <br /> Another, somewhat easier way of obtaining the files is using a MSDOS boot disk. This method doesn't require you to go looking for some software, or using special burning software. Just insert a floppy, right click on it in My Computer, and click on format floppy. When the menu appears, mark the box for "Create a MS-DOS startup boot disk", and then click the start button. After you have made your disk, restart your computer with the disk still in the drive. Make sure you BIOS settings boot from the floppy drive before the hard-drive. When the computer boots, you should se a screen similar to that I command prompt. "A:&gt;" is most likely the prompt you will see. First you need to change drives to the c drive. This is done various ways on different computers. "cd C:" or "C:" usually work. Next you will need to use the copy command to copy the SAM and SYSTEM files to other areas of the hard drive. The syntax for the copy command is as follows without the quotes : "C:Copy (file to be copied) (destination)" so the correct command which will get the file for you is "C:Copy C:WINDOWSSystem32ConfigSAM C:" This will copy the SAM file to the C drive. Replace "SAM" with "SYSTEM" to get the system file. Next you might want to rename these files. This is the syntax for the Rename command : "C:ren (file to be renamed) (new file name)". The command, which will rename your files for you, will be "C:ren C:SAM Whatever" if you saved it to the C drive. This will rename you SAM file to Whatever. Now restart your computer without the boot disk in and start up windows. Copy the files onto a floppy. Note : you may have to zip it as the SYSTEM file is pretty big. The reason these methods work, are because the SAM file is not in use when you aren't running Windows, and when u copied and renamed the file, it did not get used by windows when you logged on. Now on to the easy part, cracking the SAM file.<br /> <br /> <b>Section 3 : Cracking the SAM file</b><br /> There is a wealth of programs available that will crack the SAM file for you. You can also attempt to crack it by hand. I having neither the time nor the skill required to do this, used a program. Some programs I recommend are SAMinside, which unfortunately costs money, Proactive Windows Security Explorer, which actually can import the SAM file from memory, so you will not need to obtain it by yourself if you are doing this on your home computer, and of course CAIN and ABEL will do the trick as well. Most of these programs test about 4 to 5 million passwords per second, at least on my machine, so if the password if below 7 characters, it should be able to crack it in one day. However, if the password is 7 or more characters in length, then it will take a substantial amount of time. When I did this, my password was 7 characters in length and it took my computer just over 3 days to crack it.
on Dec 24, 2010 | Computers & Internet
Cannot load Vista
I dug out the Factory Restore procedure from the Dell website. If you can successfully get to the Advanced Boot Options screen with F8, there should be an "extra" item in the choices, "Repair Your Computer". If you select this, then you will be asked to select your language, followed by an Administrator login. After you log in, click "Dell Factory Image Restore" then click "Next"
If your hard drive has a bad spot where the volume information is stored, this will still fail. In that case, remove the hard drive, find somebody who can make a full copy of it ("Ghost" the drive; named for a program that performs that function; this copies hidden low level data as well as the files) to a new hard drive, and try the new drive. The volume information on the new drive will be corrupted also, but it should be repairable, and you might even get your original data back.
New hard drives can be purchased for less than $100. If your ghost and recover process succeeds, you should seriously consider getting an external hard drive big enough to hold the contents of your iMac and your new laptop hard drive, split it into two partitions using Disk Utility on the iMac (format one partition as HFS+ )Extended) for the Mac and the other as NTFS (you will have to do this format from the Windows machine; Apple is only allowed to do FAT formats for Windows), then use Time Machine on the iMac and Backup and Restore Center on your Dell (see article linked above) to make backup copies of each machine.
Dec 01, 2011 | Dell Studio 1535 Notebook
. Hi.Have a Zanussi DI720
This is a guess but try gently moving it through the cycles by hand a few times, it may just be that the timer mechanism is stuck a bit from age and or disuse. Turning it may help to loosen it up.Be gentle though.
Jun 05, 2011 | Dishwashers
T-Mobile Dash Voicecommand: What keyboard keys map to the "app1" through "app6" keys in the Voicecommand application?
The key to use for voice commands is the HOME BUTTON. This is the button that has the shape of a house on it, to the right of the green send key. Set the app to none or app 1, and it should work. It has only worked a few times for me though; it is kind of confusing. So, good luck. Also, there is an online voice command help. Go to voice command, click menu, click help.
Feb 10, 2011 | T-Mobile Dash Smartphone
How do I get past installation when I get a cyclic redundancy error? Using Windows Vista
Hello ,,,,,,,,,,,,,,,,
Try this....
The cyclic redundancy check, or "CRC" error, indicates a bad spot on your hard drive. The fact that you're seeing it when you try to copy a file indicates that the bad spot may be within the file itself.
We need to verify that and then we need to try to recovery your file and repair your hard drive.
First, let's make sure that the problem is actually with the file you're copying since it's equally likely that the problem is with the location you're copying too. This is easy. Fire up a Command Prompt window, and then copy the file to NUL:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>CD (to wherever the file is located)
C:\wherever>copy Outlook.pst NUL
1 file(s) copied.
This reads the entire file by copying it "nowhere". If this succeeds, the problem is not actually with the file itself, but the location you were trying to copy it to. My recommendation would be to copy it to a different disk entirely, or a different machine on your local network.
If this copy fails, then we've confirmed that the bad sector on your hard disk is actually being used by some portion of your file.
Now that we've confirmed that the problem is in fact in the file itself, we need to make as best a copy of it as we can, somewhere else. This sets a position of "it can't get any worse than this". Some data within the file may be lost, but you'll have copied as much as possible before the recovery efforts.
Once again, we want to copy the file to some different hard disk, or some other machine on your local network. And once again we need to do this within the command prompt:
C:\wherever>xcopy /c Outlook.pst D:
1 file(s) copied.
Two important things to note here: we've used the xcopy (for eXtended copy) command, and we've added the"/C" switch which keeps copying even if errors are encountered. As you've already experienced, the default behavior of both COPY and XCOPY is to stop if an error occurs.
Now that we've got a "no worse than" backup copy, we can start attempting to repair the disk.
SpinRite is a hard drive recovery and maintenance program. When you run it, it will perform a lengthy and exhaustive analysis of your hard disk without modifying its contents. Exactly how it does what it does is probably too technical and lengthy for this space, but one of the most important things that it does is simply this:
If a bad sector can be recovered, SpinRite will recover it."My recommendation would be to copy it to a different disk entirely, or a different machine on your local network."And many, though of course not all, bad sectors can be recovered using SpinRite.
The net result is that after running SpinRite on the drive, it will either recover the sectors and you'll have a good, working hard disk once again, or it won't - and you'll know with some confidence that the disk cannot be recovered.
In the first case, if SpinRite is actually able to recover the sector for you, then unless SpinRite tells you otherwise, I'd then happily reboot and continue using the hard drive.
If SpinRite is unable to recover some data on your hard drive, I would first reboot into Windows and, as we did above, make another copy of the file. While SpinRite may not have recovered all the bad sectors on your hard drive, it could have repaired some, and those might have been the ones causing the problem with the file you're trying to access. I would not overwrite our first "no worse than" copy, but I would save this new file, as a kind of "possibly better" copy. And then I'd plan on replacing the drive.
If you're not up for spending the money for SpinRite, then Window's own CHKDSK utility is the next best thing. It's not as thorough, and it doesn't perform the same deep analysis and recovery as SpinRite, but it can, in fact, recover from some types of hard disk failures.
Once again, in the Command Prompt:
C:\>CHKDSK /R
The "/R" parameter indicates that CHKDSK should check for errors and repair them as best it can.
Important: if this is your system drive (most often C:), this command will not actually run the operation immediately, but will schedule it for the next reboot. You'll need to reboot to actually make it happen.
After it's done, try making another copy of the file. If it doesn't work, then obviously CHKDSK wasn't able to repair the error you're experiencing. If it does, however, save that copy as a possibly fixed copy of your file.
Even if CHKDSK does repair the problem, I'm actually torn on how much to continue to trust the hard disk. You could still experience future failures.
Though I suppose that's true for any hard disk, after any utility is used. Or not.
At this point, if none of the steps above have repaired the bad sector or otherwise recovered your file, you're just a little bit screwed.
It's now time to work with the best-effort file that you saved earlier and, depending on what kind of file it is, try to recover the contents. In your example, an Outlook PST file, that means running scanpst on it, which will scan the contents of the file and attempt to recover what it can. There most likely will be data loss. Sometimes a lot of data loss. That's why I encourage you to never run utilities like scanpst on your only copy of the file. You always want the original to go back to in case there's something else in it that you can recover manually.
For other types of files and applications, it'll depend entirely on the specifics of that application as to how it will deal with a partially corrupt file, and whether or not it can be repaired.
And that brings me to my last point.
If this was your only copy of the file - if you would have suffered significant data loss had this file become corrupt - you haven't been backing up.
Start.
This was a wake-up call. Even if we successfully recovered your file, you should be very scared.
Start backing up your important data. Now.
The next time there's a problem, you may not be as lucky.
Jul 06, 2010 | Arcsoft ShowBiz® DVD 2 Full Version for PC
Apparently valve not working, how can I check it?
sounds as though the thermostatic radiator valve is stuck although the valve settings can be set to max. sometimes hitting the side of the valve will free the stuck spindle & get it working again.
If not a drain down of the system & a new valve fitted
Kindly
Richie
Dec 15, 2008 | Plumbing
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
