Question about LG 24 in. LDF 7811 Built-in Dishwasher
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
  • 4,323 Answers
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Posted on Mar 26, 2011
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
My lg ld 1403w1 dishwasher fills with water and then error code I.E appears have bailed out water and tried it three times same result
Hi june1245,
I.E means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame (varies on model) - Make sure of the following first:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Un-kink it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jun 06, 2011 | LG Dishwashers
Stopped - no error message, power, drainage lines all good Andy
No Power on when the power button pressed.
Check out the web site
http://spares.bigwarehouse.com.au/file.php?document_id=5831
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lg dishwasher stops throughout the full cycle
If you are still having problems with your LG dishwasher, turn off the hot water supply to the dishwasher and remove the hot water inlet pipe (remove the lower, front panel (toe kick plate) )
Check the screen/filter at the water inlet on the dishwasher.
Reconnect the pipe and turn the hot water supply back on.
Test out and enjoy!
Apr 01, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDF 7811 Built-in Dishwasher Logo
464 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
