Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
Toilet is very slow filling tank with water to flush
    Scholar:
  • 130 Answers
Look inside the reservoir. There is a cylinder sticking up at about water level or above. That cylinder should have a small hose (tube) going into the top of it attached with a small clip. This helps fill the bowl with water. These come off from time to time and just fall down into the water and dont do what they are supposed to do. Hopefully this is the problem.
Posted on Mar 26, 2011
How do you flush fill valve
Usually there is a screan that is on the bottom of fill valve on the outside of tank were the water inlet is you can shut water off and remove srean and flush out if it dont have one you will have to remove the valve from tank and flush out in kitchen sink or faucet.
Sep 20, 2014 | Kohler Home
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
It takes a long time to fill the tank
There could be partial blockage of the water supply line causing a slow fill.
Feb 20, 2014 | Kohler Cimarron Comfort Height elongated...
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
My toilet makes a high pitched whine after being flushed. Pressing down on the top of the tank mechanism makes it go away but the next time it flushes the whine returns.
I would suspect that the flush valve has a blokage in it that is causing a harmonic distortion to be transmitted thru your cold water piping.. One way you may be able to help this is to slow fill rate down on your flush valve. If your fush valve has a seperate float to shut off water supply to tank when it;s full there should be a adjustement screw onside of valve where float rod goes in. Adjust screw down to raise float and thus slow fill rate of tank, this should help with the noise. Ifyour toilet does not have adjustable float see if you have a valve on incoming water supply. If you do you can try slow down flow thru supply valve and see if that helps, Thanks
Nov 18, 2010 | Kohler K-11466-0 White Cimarron Comfort...
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
Our American Standard toilet flushes ok but fills back up real slow. Very little water comes out of the hose that goes in to that tube. Can you help Thanks Howard
Okay Howard. It seems that the fill or float valve inside the toilet tank needs to be replaced. If you have a pair of channel locks / large pliers and some patience, you can do this yourself and save $ on a service call. This Solution is providing that you have good water pressure everywhere else in the house. First turn off the water on the supply line going to the tank. Flush the toilet (with the water off) to empty the tank. Take a towel / sponge / or wet vac to remove any remaining water. Remove the nut on the underside of the tank that holds the float / water supply to the tank. Now that you have the water float removed you can go to your local hardware store / Home Depot / or Plumbing Supplies Store and get a new fill valve. There are different kinds but they all do the same thing, fill your tank. I use a Fluid Master, But you may have to use one like you have. The Store will assist you. They are only about $10 - $15 Bucks or so.......Install the new float according to directions.....It is pretty simple. Insert your new float stem into the hole with the proper rubber washers and tighten carefully for a good seal. Insert the new black hose into the overflow tube and you are in business. You will have to adjust the water level to about a 1/4 Inch below the overflow tube for a good flush!!! I hope this helps you with the slow tank fill.............Joe
Jan 13, 2009 | American Standard Colony 2388.012.222...
Toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
304 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
