Question about ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3, DDR3-1800, nForce 630a, HT 3.0, Onboard GeForce 7050PV, VG... Motherboard
1.help how to update the bios..i cannot locate the bios file from the open window. 2.the motherboard asus m4n68t m v2 has a feature of core unlocking but when i tried it seems unstable. i have amd athlon2x 3, i maybe successfully unlock it and it becomes phenom2x 4 as it show to my system...it seem unstable especially the graphics.
  • kramz_etiur8 Mar 30, 2011
    thanks for the information,really help a lot.ok i will just stick to the normal core of my amd processor athlon2x 3.rather than damaging my cpu.
    Problem Solver:
  • 10 Answers
1. Go to your products site to locate the latest BIOS update.
2. Core unlocking can be very dangerous. The 4th core is locked for a reason, usually because of a manufacturing defect. If it seems unstable then it probably is. Some people that you see online get lucky and successfully unlock the 4th core. However, this is not the safest thing to do and could actually damage your CPU. If you think it is unstable, then you should probably restore it to its factory defaults.
Posted on Mar 29, 2011
M4n68t-mlev2 unable to perform in windows xp
Hello did you install ALL the drivers for both systems ?
If not you can download them here:
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_LE_V2/#download
Please select your windows system.
Open the folder with the driver you want and click on global for download.
Unzip the file before you install.
Good luck
Dec 25, 2012 | ASUS M4N68T-M V2 Desktop Motherboard -...
Asus Mother board M4n68T-M LE V2 not supported seagate 1tb internal hard disk
It should support drives up to 2TB automatically unless you are using an operating system older than Windows XP. If for some crazy reason the board is limiting you it may be a glitch that is fixed by upgrading your Bios. You can download the latest Bios for your motherboard here:
Jun 25, 2012 | ASUS Computers & Internet
Asus M4n68t-m le v2 not supported internal 1 tb hard disk
It should support drives up to 2TB automatically unless you are using an operating system older than Windows XP...
I have a ASUS M4N68T-M LE V2 motherboard, whenever i am formatting the computer and installing windows xp operating system after installation of the sound drivers given along with the motherboard after few...
Try and fit a discrete sound card and disable the onboard sound in the bios. Sometimes a chip will fail and quite frankly it is cheaper to buy a PCI sound card rather than a new motherboard.
May 28, 2012 | ASUS Computers & Internet
Hello sir i have new M4N68T-LE-V2 with new amd athlone 260 my prob is when i install drivers in xp and restart then blue error appears i update bios change install directory also change ram and try...
Hi, you can download a manual here if you don`t
have one:
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_V2/#download
Please select your operating system 32 or 64 bit system.
Select manual and click on global for download.
Unzip the file before you can read it.
My guess is that your harddrive has a defect.
Or the windows disc is broken so all the files on
it not being loaded properly on the harddrive.
A blue screen is typical harddrive failure.
Try to change the harddrive with a new one
and see if the problem helps you.
Aug 31, 2011 | ASUS M4N68TM Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
How can i update the lastes bios
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
Apr 28, 2011 | MSI P31 Neo-F Core 2 Quad Socket 775...
Usb overvoltage detected system will shut down in 15 seconds
Seems to be a common issue with this board.
Couple of things to check
In the Bios, check that the Voltages are within 10% of their nominal values (notably the 5 volt rail). If they are, then try replacing the power supply first
You can turn off the uSB 2,0 controllers in the bios as a precaution and install a seperate USB PCI card .
From what I found out though, the common opinion is that the motherboard is faulty, If it is still under warranty I'd RMA it
Dec 31, 2010 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Hi I have V2 marked on my A8N-E looking for updates
The V2 you see stands for, nForce4 Ultra.
To download the drivers for your Asus A8N-E board click on this link;
http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Choose your operating system from the drop down window & click the Search button. All drivers, manual, bios files, utilities ect will be listed. (Never flash the bios unless you are correcting an issue).
Asus eStore link;
http://estore.asus.com/shop/category.asp?catid=133
Cheers!
Mike
Apr 25, 2009 | ASUS A8N-E Motherboard
ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3, DDR3-1800, nForce 630a, HT 3.0, Onboard GeForce 7050PV, VG... Motherboard Logo
310 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
