Question about ViewSonic VX910 19" LCD Monitor
I have a ViewSonic VX910 LCD monitor. I turn it on and it comes on for a second then goes black. I did replaced all five capacitors in the power supply board, but it didn't help, still the same problem. what other parts that could possibly be not working?
  • 3,083 Answers
AllI can think of is that a tripler or inverter could be breaking down, causing the unit to go into auto
shutdown mode. Some devise is breaking down, and causing the unit to shut down.
Not an easy problem to troubleshoot unless you've got a schematic and tech skills.
Hope this helps
Posted on Mar 26, 2011
When I turn on monitor it lights for a few seconds and then goes off...continues to blink on and off never lighting fully. After a while it goes black and will not come on.
You can try to replace all of bad capacitor on power inverter board. After all of failure capacitor was replace, try to turn on.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | ViewSonic VX910 19" LCD Monitor
I turn it on and it comes on for a second then the goes black
You need to open it up and inspect the capacitors (look for bulging top/seal), burnt inverter transformers, resistors, etc. in the power supply/Inverter board first, post back what you find so we can guide you further. See example of failed Viewsonic monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 16, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
I have a viewsonic VX910 and the picture goes off and on. Picture lasts less than a second. I replaced the 3 caps but no good. I measured some power points on the PSU and see the drop, even the A/C drops...
This could be caused by a few things. First, be sure the capacitors you used are low ESR. You can't use capacitors from Radio Shack, they can damage the electronics. Second, on the bottom of the power supply board you will find 4 transistors, they may be blown out. Check them with a multimeter or transistor checker. If the transistors are blown, we carry them is stock if you need them.
Contact us at: tech@ccl-la.com if you need any additional help.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 02, 2010 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Jan 26, 2009 | ViewSonic VX910 19" LCD Monitor
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD...
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Apr 22, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
139 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
