I bought SONY LCD TV 32EX400 Full HD in Dubai UAE and i sent it to the Philippines, they can use the TV but the resolution is only Standard Definition not Full High Definition and it so blurred. do i need to re-channel my sony LCD TV?
  • 3,083 Answers
All I could suggest is that they make sure they're using the HDMI cable to connect their cable input to the TV. That's the only thingI can think of that would cause this.
Posted on Mar 26, 2011
32ex400 lcd tv hdmi no work
The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip".
Good Luck!
Rich Lilja
Dec 18, 2013 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Sony bravia 40vl130 Serial No.8002109 made in Mexico during Aug 2007 bought from usa not working in dubai UAE what could be the reason ??? Can You please HELP ???
Hello
Bravia 40Vl series in not system compactable. The bravia you owns have only NTSC and ATSC system and is only meant for exclusive use in US. It can't be worked with PAL system in Dubai. So this set is worthless for you as you are in Dubai, India or any other part of the world where only PAL system is the standard for both transmission and recording. OK.
Apr 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do i stop text showing under the picture
go to your menu and shut off any closed caption cc
Jan 17, 2011 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
What does HD ready mean? Is my Sony Bravia LCD acctually an HD TV or not?
High definition ready is different to Full High defintion for the simple reason the software is different to prove play a HD play station game on both and you will immediately see the difference in picture quality however the difference is not so significant on your normal satellite HD channels depending on the resolution the TV can produce
Nov 23, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
T.V dosen't work with battery or inverter
The TV use 110V 60Hz sine wave AC, after rectified will be 156V DC, your inverter may be output 110V square wave AC, after rectified only 110V DC, it is too low for the TV work. except it can adjust to 155V.
May 18, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
85 people viewed this question
 Grubhead
Grubhead
