Question about Apex Digital PF2020 20" TV
Sound goes out
First of all we have the TV connected to Direct TV. However, when we initially turn the TV on it comes on showing a picture with "no sound". With the remote for the TV, we have been pressing the "recall" button twice and the sound comes on. It may stay on anywhere from 15 minutes to an hour before it goes off again. And we repeat the process which is very annoying when you are trying to watch a movie. Please help!
Punjabie if you have a receiver box for direct tv try unplugging the box then plugging it back in after about 10 sec that should fix the issue, if not then i would call direct tv may be something with their box
Posted on Aug 04, 2008
SCREEN BALCKS OUT AND TURNS OFF
Motherboards don't have screens. But, you probably have a failed inverter in your TV.
Jun 02, 2013 | LG Computers & Internet
ViewSonic 37" Wide (N3733W) TV Set that is connected to Direct TV has picture but no sound.
Based on your description, it is possible that the power supply is starting to go. Before doing anything, first check to see if it is the TV or the source. Use a few different sources to narrow down the problem. You didn't mention what type of hookup you used from the receiver to the TV. Assuming you are using HDMI, it is possible that the cable is intermittent. Try using a different one. Also try as below.
1. Once the TV is working with sound, what happens if you turn the TV off and then back on, is the sound still there?
2. Use the TV antenna input to see if you can replicate the problem using an antenna. If the problem is indeed the TV, it should do the same with the antenna.
Feb 17, 2013 | ViewSonic Televison & Video
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
Jul 16, 2017 | LG 37LC7D 37 in. LCD HDTV
Sanyo plasma tv shows no picture. Picture comes on and goes off. Sound come on and goes off.
check to see if your input signal is connected correctly. Might not be a tight connection.
May 25, 2012 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Tv has sound but no picture initially picture comes on but then goes off after about 2 secs
Turn off the tv from the mains and then restart. Or try a different extension/input
Oct 05, 2011 | Televison & Video
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Apex Digital PF2020 20" TV Logo
70 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
