Question about Samsung WF316BAC 3.79 cu.ft High Efficiency Front Load Washer
Code 7e silvercare malfunction i need to know proper procedures for repair code 7e
  • 6 more comments
  • kevinskrew5 Mar 26, 2011
    thanks but after i disconnect kit and or pcb what should i do next.
    i dont see anything burnt or broken i have tried running without kit or pcb connected and still get same code are the ion bars inside the kit? why cant it be bypassed and not show the code if nothing is connected to send that message? By the way thanks for your help and patience.
    sorry actually with further inspec on the silvercare kit/water guide there is a white looking burn or discoloration at the grey wire
    so do i order kit/wtr guide?
    ill buy that but why wouldnt it be able to be bypassed or disconnected and code not come up?
    Well I ordered part and will be very curious how it works out. I am always a bit skeptical but my tech. was very responsive and as helpful as possible. Thankyou for the support and will reply with conclusions. again thankyou.
    no such luck wire looks good 7e still comes up with silver kit connected or not
    will od thx
  • 4,323 Answers
Hi
Error code 7e means washer has detected excess silver ions in the washer. To try and clear this error empty the washer disconnect the power cord and water hose, and try to clean the water inlet filters. If cleaning the filter doesn't help then you would need to check the Silver Kit/Silver Care Board. The washers utilize two pure silver plates that serve as electrodes for the water inlet system. During the wash and final rinse cycles, silver ions are sprayed into the tub. To check Silver KIT/Silver PCB--
Silver (AG) KIT--
1. Unplug the unit. 2. Remove Top Cover. 3. Remove screws(2ea) from the rail. 4. Disconnect the wire harness. 4. Remove clamps and hoses.
Silver (AG) PCB-- 1. Unplug the unit. 2. Remove Top Cover. 3. Flip open the PCB cover. 4. Disconnect the wire harness. 5. Remove screws (2ea) on the frame.
Hope this helps... Please post back if you need more information. Daniel
Posted on Mar 26, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 26, 2011
    Hi
    You need to check for wiring connections to and from the Silver Kit and Silver PCB. Inspect for any burnt or disconnected wires on the board. Replace if necessary.
    Daniel
  • Daniel Scott
    It is due to a shorted connection or Silver kit failure, you would need to replace the silver kit if the wiring seems to be OK. You can buy the parts for your samsung washer from this link--- Samsung WF316B Parts
    Hope this helps...
    Daniel
  • Daniel Scott
    When you use Silver wash feature then the Silver Kit and Silver PCB are enabled and release silver ions into the washer. Moreover the control board is programmed to receive signal from Silver Care PCB, when the Silver care board doesn't detect Silver Kit then it displays error 7e. To bypass this you should not use Silver wash feature. To reset the error message you can try this---
    To enter the Special Test Mode, press the Signal and Extra Rinse Keys for 3 seconds or until the unit sends out beeping sounds. Wait for a minute then press Signal and Extra Rinse Keys for 3 second again, or Power Key. If no key is operated during Special Test Mode for 5 minutes, the machine will return to normal user mode.
    If the error code still appears then check the silver nano wire connected between the control board and silver care board.
    Hope this helps...
    Daniel
  • Daniel Scott
    Wires may look good but may not have continuity. I'll suggest you to check continuity with a multimeter. Also, make sure to check the Main Control board for any disconnected wires. If this doesn't help then we'll wait for the Silver Care kit to arrive.
    Daniel
I have a ford focus 2008 sedan automatic. I get a transmission malfunction message.
Diagnostic Procedure Before Repair
Step 1 - Clear all DTC's with a engine scan tool (diagnostic trouble codes.) Visit - Scan PCM
Step 2 - Start the engine and observe the MIL, if it does not illuminate continue to next step (service engine soon or check engine light.)
Step 3 - Drive the vehicle while trying to maintain a constant throttle position as it accelerates up through all four gears. If the transmission is shifting properly, it should be in 4th gear by the time you reach 45 to 50 mph on level ground. Repeat this procedure from a standing start 3 to 5 times. Rescan the PCM for trouble codes, if none appear the problem could have been a onetime occurrence. If a trouble code has returned repair as needed and recheck system. Hope This Helps !!!
Aug 19, 2017 | Ford Cars & Trucks
When I put my 1998 Pontiac Transport Montana into gear the ABS and TCS warning lights come on and stay on
The only way to know where the concern is would be to retrieve the trouble codes; without scan tool, this information not provided by the manufacturer.
Self-diagnosis procedures (with the diagnostic scan tool):
- With the ignition switch OFF, connect the diagnostic scan tool (Hi-scan pro) to the data link connector located under side of master vacuum in engine compartment.
- Make sure the ignition switch is in the on position, and then choose correct vehicle and model, proceed to diagnostic data link menu item.
- Choose the inspection item after initializing the unit.
- Press malfunction code detection No. 1 and diagnostic scan tool will display any malfunction code found.
Notice: A malfunction code is a four-digit number that is continuously output until the failure code is erased by the diagnostic scan tool.
- From the list of failure codes, verify the failed part and repair it according to self-diagnosis procedures.
- After repair, erase all malfunction codes stored in the ABS control unit by selecting inspection item (No. 4).
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 19, 2011 | Cars & Trucks
How do you reset abs sensor on kia sportage
The only way to know where the concern is would be to retrieve the trouble codes.
Without Scan Tool: this information not provided by the manufacturer.
- Press malfunction code detection No. 1 and diagnostic scan tool will display any malfunction code found. Notice: A malfunction code is a four-digit number that is continuously output until the failure code is erased by the diagnostic scan tool.
Nov 17, 2011 | Cars & Trucks
Eurovox
16.45 on the 30 Nov
These codes working for me on T/W
B7 19 92 E2 9B 15 AF 96
3C 12 5C 17 D4 3F 7E 64
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
New code needed
30TH NOV AT 4.30PM
5A 01
98 B0 BA 52 D3 21 08 B4
THATS TONITES CODES FOR TELEPEST
CODES
00= 93 14 d0 7e 5c eb 74 4e 01= 30 80 b3 a3 fc 72 6b 3d
Nov 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
2002 kia sedona with a trouble code p0350
Check Ignition Coil 1. IG KEY : OFF , Engine : OFF 2. Disconnect ignition coil connector B-20/ B-21/ B-22. 3. Measure the primary coil resistance. - Connect the negative (-) terminal of a 3V power supply to terminal 2 of the power transistor; then check whether there is continuity between terminal 3 and terminal 2 when terminal 1 and the positive (+) terminal are connected and disconnected. A. [Specification] 1) In case of connecting terminal 1 with the positive (+) terminal Resistance between terminal 2 and 3: Approx. 0.78Ω±10%(20°C(68°F)) 2) In case of not connecting terminal 1 with the positive (+) terminal Resistance between terminal 2 and 3: infinite(∞Ω) 4. Measure the secondary coil resistance between the high-voltage terminals of the ignition coil. A. [Specification] Approx. 13.0 ± 2.6(kΩ) (20°C(68°F)) sor35d030033.gif sor35d030034.gif 5. Is the ignition coil normal? yes_icon.gif YES 1) Ignition coil is OK. 2) Possibility of PCM malfunction 3) Test with a new PCM and check for proper operation. If problem is corrected replace PCM and go to "Verification Vehicle Repair" procedure. no_icon.gif NO 1) Test with a new ignition coil and check for proper operation.If problem is corrected, replace it. 2) Go to "Verification Vehicle Repair" procedure. findme(''); findme(''); findme('');
Oct 05, 2008 | 2003 Kia Sedona
Eurovox codes
eurovox codes 19/10/09 5a01 00 CF530c3379617185 01 525e8d45fc75f64a
Sep 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Error code 7E
Silver Care Kit (Silver Care PCB) Failure.
Check Silver Care PCB ,Main PCB & Wire harness
Jan 27, 2008 | Samsung WF337AA Front Load Washer
Samsung 306BHW-Error code 7E
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
Dec 03, 2007 | Samsung WF337AA Front Load Washer
Samsung WF316BAC 3.79 cu.ft High Efficiency Front Load Washer Logo
1,046 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
