Question about Samsung PN50B430 50 in. TV
My PN50B430 50" Plasma has
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
  • 92 Answers
SOURCE: philips 42" plasma blue line down left side
the lines are most likely the panel which isnt cheap
the blue speckles are just a voltage adj. on the y sistain if you feel confident enough you could try this yourself(though expensive equipment is usually required i do without). what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the blue goes away(a little does alot).
Posted on Jan 20, 2008
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
gsalmen
  • 77 Answers
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
Posted on Jul 10, 2009
  • 304 Answers
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
LG DR4810 black and white lines at top left and side of Picture extending accross middle of picture window. How Do I remove these?
I think you should take it back, cause! defective laser pickup, or the video processor, and possibly the audio/video cable, "replace to be sure"
May 08, 2012 | LG DR-4810 DVD Recorder
Multiple vertical white lines
hi,
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrlbt-xl-eax35683901-ebr35855501/
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrrbt-xr-6870qsc107a-6871qrh073a/
If you need any more assistance feel free to contact me through fixya.
Ajin
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Black and white line on screen
contact on
SMC General Sales (Online Sales Service (English only):
3333 SANYO Road
Forrest City, Arkansas 72335
E-mail: sales@sanyotv.com
Phone: (800) 877-5036 Ext. 1512
Jan 23, 2009 | Sanyo DP42746 42 in. Plasma Television
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Panasonic th37px60
Just taken mine in for repair and was told this. "After checks to Switching and Data flow to PDP, Suspect the Plasma display panel to be at fault
which also may well have caused damage to the buffer and logic boards."
I am presently trying to get currys to replace it as it 18 months old.
Forgot to say was quoted £1200 to fix!!!!
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Samsung PN50B430 50 in. TV Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
