When I start up my computer it says beep sound and Not turned on what is the couse?
    Guru:
  • 433 Answers
More clear plz to solve thank you
Posted on Mar 26, 2011
Can you put mango in a cous cous salad? I really like the idea but it sounds a bit weird.
It's totally fine to stick mango in a cous cous salad. I do it all the time. Try throwing in some chilli and plenty of parsley and coriander. Just make sure that your mango isn't over ripe or it will make the cous cous mushy.
Feb 20, 2013 | Cooking
My computer always beep. when i am printing my computer beeps very long so i turn it off. i thought it was the cpu overheating. i put some thermal paste and turn it on when the computer is in the desktop...
hi Robin.
if your computer is making a beeping sound when it starts. No, you're not crazy, your computer really is beeping, and the sound may be coming from inside your computer, not your speakers.
These beeps are called beep codes and are used by the BIOS (the software that runs your computer hardware) during the POST (an initial test to make sure your computer is OK to start) to report certain initial system errors. If you're hearing beep codes after you turn your computer on, it typically means that the motherboard has encountered some kind of problem before it was able to send any kind of error information to the monitor. The beeping, then, is a way to communicate a problem to you when the computer can't show a proper error on the screen.
Follow the steps below to determine what computer problem the beep code is representing. Once you know what's wrong, you can work to fix the issue.
How to Troubleshoot Beep Codes
Figuring out why your computer is making beeping sounds should only take 10 to 15 minutes. Solving that problem that you identify is another task entirely and could take a few minutes to hours, depending on what the problem ends up being.
  1. Power on the computer, or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're probably not going to make whatever problem you have worse by restarting a few times.
  1. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short (or all the same length), and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    I know this might all seem a little crazy but this is important information that will help determine what issue the beep codes are representing. If you get this wrong, you'll be trying to solve a problem your computer doesn't have and ignoring the real one.
  1. Next you'll need to figure out what company manufactured the BIOS chip that's on your computer motherboard. Unfortunately, the computer industry never agreed on a uniform way to communicate with beeps, so it's important to get this right.
    The easiest way to figure this is out is by installing one of these free system information tools, which should tell you if your BIOS is made by AMI, Award, Phoenix, or another company. If that doesn't work, you could open your computer and take a peek at the actual BIOS chip on your computer motherboard, which should have the company name printed on or next to it.
    Important: Your computer maker is not the same as the BIOS maker and your motherboard maker is not necessarily the same as the BIOS maker, so don't assume you already know the right answer to this question.
  2. Now that you know the BIOS manufacturer, choose the troubleshooting guide below based on that information:
    Using the beep code information specific to those BIOS makers in those articles, you'll be able to figure out exactly what's wrong that's causing the beeping, be it a RAM issue, a video card problem, or some other hardware problem.
  3. Try to turn off beep sound in the BIOS
More Help with Beep Codes
Some computers, even though they may have BIOS firmware made by a particular company, like AMI or Award, further customize their beep-to-problem language, making this process a little frustrating. If you think this might be the case, or just worried it could be, almost every computer maker publishes their beep code list in their user guides, which you can probably find online.
See How to Find Tech Support Information
Dec 13, 2017 | Biostar MCP6P-M2 Motherboard - v6.0,...
My dv6000 dont start . i have black screen with one long beeb and two short beebs
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Making beeping sound when i start up the computer
A beep sound can be due to memory problem.
First use the following steps:
1 Turn off the system and disconnect power cables
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If you still get a continuous beep sound, the next step will be to re-seat memory modules (after turning off the system).
Mar 08, 2010 | E-Machines eMachines Desktop PC
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Intel D945GCNL Board No display
Dear user, this problem can be coused by many things.
1, The memory you have installed is not compatible with your system.
2, Power supply failure.
3, Contact issue between the socket and the module.
Try thease:
Take a brush and clean the sockets.
Power on your computer without the memory modules, if you hear beep it could be a health signal :D.
Power off the system.
Clean your memory module pins with alachol or other cleaner liquid.
Wail till it dry, inster it back to the socket and move a little ud and down to catch ancontact.
Power on and now shold be work fine.
If this ain't works. Try other brand of memory, kingmax or kingston. They usually shipps with 99 of good modules from 100.
Good luck.
Mar 22, 2009 | Intel D945GCL Motherboard
Who does the music to the audi r8 advert? it's buggin the **** out of me it's a nice tune and starts with the phrase" beep beep beep? somebody must know so please help me
if its done at every music than its a player brand policy like
automated defining singer ,play time , etc.
thats depend upon your player.
if dont doin at each time than dont worry some plays are worthy couse of this ..!
THNX
May 14, 2008 | 2005 Audi Le Mans
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
