Question about HP Deskjet D2660 All-In-One InkJet Color Printer
There is a red light which says there is a paper jam but there is no paper in the machine
    Novelist:
  • 107 Answers
Dust and small particles often causes this. You can try blowing air inside the printer or between the rollers.
Posted on Mar 26, 2011
My canon 2870 machine show paper jam and red light blinking
have got the manual for that machine ? it should explain how to remove paper jam if not you will have to remove the paper feed roller and carriage to clear it
Mar 21, 2018 | Canon Office Equipment & Supplies
Paper jam showing red light
did you get a full sheet of paper back out when you removed the jam? If not there is still a small piece of paper in the machine. You will need to get a flashlight and look carefully in the center of the path from where the paper starts (the paper tray) to where it comes out when it is done. if you cannot find any do this: best if you open and close all doors and lids. even the doors behind the printer if there is one. If that does not help try this: Turn off the printer, unplug, count to 10 then plug back in and restart. If the light is still on then light is saying a sensor is seeing a piece of paper or thinks it does. It is possible while you pulled the paper out you pulled a sensor flag out of its holder. By pulling the paper out opposite the paper moves through the machine can cause this. always try and remove a jam with the flow of paper, in other words the same direction the paper travels not backwards. Once fixed can prevent this failure in the future.
Jul 10, 2012 | Xerox Phaser 3117
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
Nov 29, 2010 | Canon imageRUNNER 2020i Black and White...
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Red light on as well as green,what is the red light
The red LED can mean one of two things -- either the shredder head is not assembled correctly (did you take the shredder apart recently?) or there is a paper jam inside the machine. Sometimes the jammed paper is far down and hard to see.
Jan 30, 2010 | Fellowes PS60-2 Shredder
A paper jammed and I pulled it out. Now the red light is blinking and it says clear paper jam but there is no jam. How do I get it to work again.
Remove all the paper from the recording paper tray and then turn off (count to 10 ) and on the machine. Then reload ALL the recording paper together. Also, before doing this open the printer cover and remove the cartridge to make sure there is no pieces of paper stuck inside the machine - then carry out the above procedure.
Good luck
Sep 25, 2009 | Canon FaxPhone L75 Plain Paper Laser
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Paper Jam error - red light flashing, but no paper jam!
There may be some tiny shard of paper stuck in some inaccessible part of your printer. Examination with a bright light source may help you find it.
Sep 17, 2017 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Red light flashing on canon laser 7000 Fax , no paper jam found.
doesnt this machine have a tray that comes out the rear of it... it may be empty
Dec 23, 2008 | Canon LaserClass 7000 Plain Paper Fax
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
HP Deskjet D2660 All-In-One InkJet Color Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
