Question about Maytag MSD2657H Side by Side Refrigerator
My refrigerator is freezing everything on top shelf. I have it set to 1 and still freezing. What is the most common perpetrator?
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Mar 26, 2011
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 22, 2011 | Refrigerators
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Top shelf on refrigerator side freezes everything into ice
well..that's most likely due to a problem with the relationship between the control and the compressor.
is your unit under warranty?
Jun 03, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Maytag MSD2657H Side by Side Refrigerator Logo
155 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
