Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Thermostat 44100b The previous ownere left me no manual. I don't know what all the buttons do. I want it to cool down. I set the temp to 74 and there is a little square that flashes but it doesn't get cooler. What do the buttons do? One says program, one says hold/ret. Any ideas? Jerry Killrkey@aol.com
  • 2 more comments
  • Anonymous Nov 13, 2008
    hunterr progammable thermostat 44100B
  • mercboy58 Nov 16, 2008
    need the manual
  • Anonymous Nov 22, 2008
    how to programm my thermostat
  • Anonymous Jan 27, 2009
    I need a manual for Hunter thermostat 44100B.
3 Suggested Answers
SOURCE: We want to set the cooling temperature lower manually on the thermostat.
lost manual need to know how to program
Posted on Jul 23, 2008
  • 277 Answers
SOURCE: Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Posted on Jul 22, 2010
I would like to set the cooling temperature on my LUX TX9600TS thermostat below 74 degrees. At this time I can not get it to go lower. Is there a way to change that ?
Lux tech support 856-234-8803. I Google your tstat info and there is a downloadable manual that explains it. If I read it correctly, set it to cool, hold menu button, when screen changes scroll to "cooling limit", enter 00(that's like a pass code), then it's probably set to limit at 74. Lower that setting. Now from a professionals opinion, someone may have set that to 74 because that machine may have a history of freezing up when set below 74. Most all cooling systems are designed for a 75°f indoor at 95°f outdoor temps and 55% RH(humidity). Anything beyond that is also beyond design specifications. So it may freeze up which has the potential of compressor damage.
Oct 11, 2017 | Heating & Cooling
No heat model 44100b
First make sure that your heating system is on (gas turned on if applicable). Check the unit for any error messages. My furnace has a blinking LED for trouble-shooting. However, the typical issues for it are: blocked air inlet and burner ignite the gas (alternatively, pilot light unlit). Once, the problem has been with the circuit board but that failed in the summer. Make sure the circuit breaker is on and that the cover of the furnace is fully seated. (This can be an issue after changing the filter.)
Next change the batteries if they are low. (This model needs new batteries every 30 days or so since it doesn't use AC power.) Make sure that the thermostat is set for heat. If this is a replacement thermostat, double-check that the wires were connected to the correct spots. (You should have labeled these when the old thermostat was removed.) Tighten all of the terminal screws. Use a unbent paper clip to press the reset button on the thermostat (just below and to the right of the up/down arrows). If the furnace works and the above do not solve the problem, replace the thermostat.
The manual for the 44100b is available here: http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44100.pdf .
I hope this helps.
Oct 20, 2011 | Hunter Fan Company 5/1/1 Programmable...
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat will not go below 74 previously would go to temp set.
Once it shuts down it will stay off for about five minutes to protect the compressor...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 08, 2010 | Sharp AF-S125MX Thru-Wall/Window Air...
I have a honeywell digital programmable thermostat in my home, it will not go any cooler than 74 degrees...i have tried to press the buttons every which way but it will not go any colder.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 06, 2010 | Honeywell Electronic Programmable...
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
How do you set the temperature on the a/c
It depends on the make or model but usually it is a simple arrow(either up or down). The older ones though have a sliding bar that you use to set the temp you want.
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
652 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
