The smart drive comes to the last washingt cycle that is the last rinse and then wont do the final spin and starts beebing.
    President:
  • 1,554 Answers
The machine will not do the final spin unless the water is drained first from the tub. You problem is likely a draining problem either due to a clogged/kinked drain hose or a blocked drain pump. The machine is also equipped with a self-diagnostic program that flashes the fault code through the Wash Progress LEDs when a problem is encountered. From left to right and numbered 1 to 8, indicate which among the LEDs are lit or flashing as the machine beeps. The 3rd, 6th, and 8th LEDs lit or flashing indicates fault code 37 which means pump blocked error.
Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Also check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diveter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 26, 2011
Spin not working on final cycle
no rinse at all or just at second final cycle? if so its either bad clutch, tranny, motor coupler, belt broken, or even door switch out? depending on either a belt or direct drive motor
Dec 19, 2014 | Washing Machines
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
I have a Fisher and Paykel smart drive 701 series washing machine and after I turn it off three lights (rinse, final rinse and spin) constantly flash in time.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
GW709 MACHINE SMART DRIVE LOAD 7.5
hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Aug 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Wont spin
you have to check all the harness connections on this machine and when you realize that this is going to happen often you may want to consider tossing this in a dumpster.
May 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
