Question about Dynex Televison & Video
WHY DOES MY AUDIO SOUND SO WEAK? COULD IT BE MY INPUT OUTPUT CABLES?
  • 902 Answers
It very well could be especially if you are using optical cables.
Posted on Mar 26, 2011
  • 3,083 Answers
The problem could be bad cables, but it could also be your settings. Go into your menu and reset it, just to make sure some other settings haven't affected the sound. My neighbor had this problem and we fixed it with menu settings on his Sony, but I can't remember the specifics of it.
You have to basically replace cables to see if they're the problem.
Good luck, and hope this helps.
I have it setup on my Samsung TV with RCA cables, but no sound comes out
Why do you need to use RCA cables as a TV will produce sound through the internal speakers without any cables required.
May 24, 2016 | Samsung Televison & Video
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I want to play normal tv sound thru the surround sound, but do not know what cables to use? i have an LG 460 tv, and a sanyo dc-ht818, it doesnt seem to have TOSLINK or HDMI inputs, so what can i use?
The Sanyo has stereo analog LINE INPUT jacks. Run two RCA audio cables from the TV to these jacks and select this LINE INPUT FUNCTION on the Sanyo. If the TV has no analog audio output jacks you can even use the headphone output by using a 3.5mm adapter to RCA audio connectors.
Mar 11, 2011 | Audio Players & Recorders
I have a great picture but no sound. What can I do?
There is more than one thing to try. First make sure you have sound cables attached and if so that they are attached to the right spot on the television. Coming from a cable box, dvd player, and etc. the red and white audio cables should be attached to the same input input input input (did I just say input) as the video cables. That is normally the problem when I am supporting people--they normally connect the sound cables to the television's output.
The second problem is usually that there are no sound cables attached. If you are using component cables you should have a total of five green blue red white red attached.
The third problem is usually that an hdmi cable is going between the cable box and the television and the cable box is not set for audio output hdmi. Please check the settings in your device.
The fourth problem is usually that the cables themselves need to be replaced.
The fifth problem is usually the television is in sap but that would only be relevant if you are using the television's tuner, and only a few channels wouldn't have any sound.
Sixth and most unlikely is that the television needs a sound board/repair.
Aug 19, 2010 | Televison & Video
Channels out of balance - remote will only change left channel.
switch input cables and try this will confirm if the amp has a problem or the input signal
Jun 19, 2010 | Krell KAV400Xi Amplifier
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
I change Component Cable Video & Audio 6 cables
I might sound stupid but Double check that you`ve connected the correct connectors as in All Inputs plugs being used or All outputs plugs being used. If you have one of these leads with 6 connectors on one lead, (Audio Input L+R, Video Input, Audio Output L+R, Video Output) You need to make sure that if you get sound from the audio input plugs, then you must use the video input plug and vice verse. Ian
Jul 22, 2009 | Panasonic PV-D4732 DVD Player / VCR Combo
DVD surround sound to come through TV at same time?
use nothing but RCA output and input to all equipment. you will need a video cables..its three cables seem/connected side by side together with all male jack at one end and to the another end. the cable are color coded; (you can get this wire from walmart or radio shack, staples and make sure you get at least 5-6 feet long cables) yellow is for video and red for right audio and white is for left audio. everything is color coded on your TV,VCR and your reciever, you cant really get it wrong on the color. fist take one of the yellow video cable to your your tv input and to your vcr output, next take the red and white audio cables and plug it in to your vcr output and to your receiver input. that should do the trick. any other question just ask and i will try to walk you through. good luck!
Jul 16, 2009 | Zenith DVT412 System
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
Televison & Video Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
