Question about Saeco Magic De Luxe Espresso Machine
Hello, I'd to pull the grinder apart to clean it because it was clogged due to water spillage. Now the coffee is grind too coarse and I can't manage to grind it fine enough. Where did I go wrong? Thank you for your help
  • maurice900 Mar 26, 2011
    Sorry but you are answering to a question I did not ask!
    After putting back together the grinder I must have make a mistake, Maybe the grinder colour spots marks have been reassemble wrongly. How should they appear when put properly.
    Thank you
    President:
  • 739 Answers
Hi
make troubleshooting to identify problems
troubleshooting instructions
Coffee Will Not Brew
Ensure the coffeemaker is plugged in and you have not blown a household fuse. Replace the fuse and reset the circuit breaker in your household fuse box if necessary.
Check the water reservoir to ensure it is filled.
Open the coffee bean container and make sure the coffee beans are ground completely.
Ensure that the Saeco coffeemaker is set to "Hot Water" and not "Steam."
5
Look at the descaling indicator light to determine if the coffeemaker is in the process of descaling the machine. Let the descaling cycle complete, turn the machine "Off" and then "On" to start the brewing cycle.
Coffee is Too Weak
Open the coffee bean container by lifting the lid.
Add more coffee beans, close the lid and press "Grind" on the control panel.
Turn the knob inside the coffee bean container to the right. This will increase the amount of grounds used to brew coffee in 9 gram increments.
Press "Brew" on the control panel.
Coffee Tastes Bad
Remove lime deposits from the machine. In a large container, mix the Saeco descaler with water, according to the manufacturer's instructions. Lime deposits can make the coffee taste bad. Open the lid of the coffeemaker's water tank and pour in the descaler and water mix.
Plug the coffeemaker in and press the "On" button on the control panel. Place a large container on the drip pan. Press "Descale" for at least 5 seconds and aim the steam nozzle at the drip pan.
Turn the hot water button counterclockwise to start the descaling cycle. Leave the large container in place until the descaler has emptied from the coffeemaker. Turn the hot water knob clockwise to "Off."
regards
Posted on Mar 26, 2011
  • HTS Sri Aman
    HTS Sri Aman Mar 26, 2011
    Thank you. it is to perform problem-solving procedure to identify the cause of your problem .. If you believe the problem arises when you do the cleaning, most likely you do not do something and most likely your installation is not absolutely wrong because the machine is capable of operating only with not a fine grind.
    5 THE COFFEE GRINDER (FIG.10)
    Caution! Only turn the grinder control
    knob, found inside the coffee bean
    container (Fig .10), when the coffee grinder
    is working and in increments of 2 settings
    at a time only. Do not insert ground and/or
    instant coffee in the coffee bean container. Do
    not insert anything other than coffee beans
    in the container. The coffee grinder contains
    dangerous moving parts; keep fingers an d/or
    other objects away. Before carrying out any
    operations in the coffee bean container, switch
    OFF the ON/OFF switch (7) and remove the
    plug from the wall outlet. Do not insert coffee
    beans when the coffee grinder i.s working.
    The quality and the taste of your coffee depend
    not only on the blend you use, but also on
    the grinder setting.
    The appliance comes with a grinder adjustment
    knob (Fig.10). T o use this feature, turn the
    graduated knob when the coffee grinder is
    working and in increments of 2. The numbers
    displayed on the knob indicate the grinder
    setting. The manufacturer sets the knob to an
    average grinder setting at the factory: if the ground
    coffee is too fine, turn the knob toward the higher
    numbers; if the ground coffee is too coarse, turn
    the knob toward the lower numbers.
    You will notice the change only after brewing
    three /four cups of coffee.
    Use coffee beans for espresso coffee makers.
    Avoid using extreme grinder positions (e.g. 1 and
    16); if this is necessary , try using different coffee
    blends.
    Store the coffee in a cool and dry place, in an
    airtight container.
    You should change the grinder position if the
    coffee does not flow optimally , specifically:
    Too fast = grinding too coarse > grind coffee
    finer (smaller setting);
    Too slow (drips and/or no flow) = grinding too
    fine > grind coffee coarser (higher setting).
    passage of the guidelines to improve
    Click here to download the full, including a diagram
    hopefully this can help u
    regards
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
I have a Saeco Incanto Rondo with a grinder related problem
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Bruce
Gold Roast Coffee
www.goldroast.ca
Jun 14, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Embarassing but...
No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
Jan 02, 2009 | Solis Maestro Electric Burr Grinder
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Clogged?
I've been having the same problem. I would clean out the burrs and it would get clogged right away. But I found that at the top of the chute where the coffee comes out that there's a flap type device. Mine was clogged with coffee. When I unclogged it it would swing freely. That seems to have helped. You need to use a skewer or long toothpick to clean it and free it. Use a flashlight to see the flap. It looks like it has a weight attached to it and probably swings back and forth as the coffee is ground.
Aug 24, 2008 | Solis Maestro Electric Burr Grinder
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Saeco Magic De Luxe Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
