SOURCE: Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
