Question about Ubi Soft Entertainment CSI: Crime Scene Investigation
Ok i try to run the game and i get this error director player error, property not found, #duration how to fix it
Director Player Error Try Free
Posted on Oct 03, 2012
Error 324 (net::ERR_EMPTY_RESPONSE): Error desconocido. when i try to play a facebook game, some times work but often not
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner it will solve ur problem
Aug 28, 2010 | Google Chrome
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Error when i run the game
download and install direct3D 9
then try this
right click on the game exe then select properties click on compatibility then choose windows xp (service pack 3 ) or the windows u know the game is working on (OR) Open control panel --> System and Security don't click it choose Find and fix problems --> Programs (run programs made for previous versions of windows press next then choose not listed and browes for the game .exe hope that will fix it
Oct 07, 2009 | ValuSoft 18 Wheels of Steel: American Long...
When i run IGI game they give me an error (no D3D drivers with hardware acceleration is not found
when i run IGI game they give me an error (no D3D drivers with hardware acceleration is not found
Jun 06, 2009 | Computers & Internet
My pc won't install I Spy Junior.
You have given no information on your PC hardware, what OS you use, or if it is 32 or 64 bit.
Here is the link to the Tech Support site:
http://support.scholastic.com/faqs.asp?sid=102838090427012117185062&pid=424&dbg=&seid=1937&pnm=I+Spy+Junior&pos=Windows+XP&tnf=14&top=Error+Messages
Apr 25, 2009 | Scholastic I Spy Junior for Windows
Installing PC game on Vista
Did you recieve the original CD\DVD - it seems like a pirated copy - please confirm if it is licensed software and we can take it from there.
Regards
Hands of Time
Apr 30, 2008 | Microsoft Windows Vista Ultimate Edition
HP Director malfunction
Error:CLR 80004005 For XP only
Fix.
Right click on the programs exe. File (ex. Quick quote Icon) go to properties, click on compatibility. Uncheck “ Run this program in compatibility mode for” Click apply, and then OK.
Mar 20, 2008 | Office Equipment & Supplies
Cant access HP DIRECTOR facility.
http://www.fix-all-dll-errors.com/xmlparse.dll/
Here is the solution for your problem.Visit the link and click the button"Fix dll errors now" and your problem will be solved.
Nov 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
Ubi Soft Entertainment CSI: Crime Scene Investigation Logo
517 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
Adam Jasar
Level 1 Expert
Edward Talavera
Edward Talavera
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
