Question about Refrigerators
Need replacement invensys water inlet valve for icemaker. Anyone know where i can find one? model k-74973-4 35W. elmira northstar refridgerator icemaker. thank you!
  • 883 Answers
SOURCE: amana scd23vw
attempt to pry off the plastic cover over the ice-maker (or look for screws). You should see at least one screw adjustment and clockwise turn is more water.
Posted on Jun 06, 2007
betz73
  • 298 Answers
SOURCE: Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Posted on Aug 21, 2008
mastatech
  • 478 Answers
SOURCE: Icemaker not filling with water
The switch from thwe i/m to fill valve is located in the head of the i/m you can jump it out in the small holes under the white cap on the i/m.
Posted on Mar 29, 2009
aasc
  • 1606 Answers
SOURCE: Kenmore Icemaker Leaking! Is the water control
Replace the dual water inlet valve . The piece the line from the wall connects to .
Posted on Jul 25, 2009
aasc
  • 1606 Answers
SOURCE: I have a Whirlpool side by side fridge, model
The general rule is to put 2/3 cup of water into icemaker , and if it dumps , but doesn't fill , replace the water inlet valve . If it doesn't dump , replace the icemaker Pt # 2198597 . Check the black fill tube above the icemaker fill cup , to see if it is clogged with ice . The fill line runs from the back of the refrig , between the liner and cabinet ( unaccessable ) , and down to the icemaker . Some of this model refrig , come with a coupling on the back , which you can disconnect and blow thru , to see if it is clear to the icemaker . If you do not have a coupling , you may want to aquire one Pt # 4211117 , in case this happens again , also , turn your freezer control down slightly , it will be a quick troubleshoot step . It sounds like the optics are ok , but I'll still give you the information .
Open the freezer door and if you get 2 pulses followed by a pause repeatedly , press in on the left side flapper door and the optic should stay on steadily . If you still get the 2 pulse and pause , then the optics are faulty . If you get no light , the icemaker is in the harvest mode ,( trying to dump ice ) . If the icemaker arm is in the normal position and no light , the optics are faulty . When the optics are faulty , replace both sides , the emiter board and reciever board . They come togather in a kit Pt # 4389102 .
Posted on Aug 29, 2009
Invensys s86
Most likely clogged or worn out diaphragm. Replace valve is only solution. Take your model number and go to your local appliance parts store or go to www.searspartsdirect.com
Sep 25, 2013 | Whirlpool Washing Machines
I have two door refrigerator no frost but the unit could not make ice it has lesser cold output may i know whats the problem on this?
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
Aug 01, 2011 | Whirlpool Refrigerators
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a Whirlpool model # ET1CHEXVB00 refridgerator. I just (few minutes ago) replaced the ice maker valve because water was no longer getting to the icemaker. Very shortly after I plugged the...
Sounds like the fill tube at the ice maker is either out of alignment or has a crack in it.
The water supply line from the water inlet valve enters the rear of the freezer and releases the water into a large diameter fill tube. The fill tubes hangs above the fill cup which funnels the water into the ice mold. If the fill tube and fill cup are improperly aligned, water may spill out instead of going into the mold.
Nov 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Side by Side Stainless steel Ice Maker water will not shut off
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
May 18, 2009 | GE Refrigerators
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Icemaker does not work
Hello Netmindr32,
You will need to replace your inlet valve. The problem is the water is slowly leaking into your icemaker fill line and freezing up. You will have a double inlet valve and the line going to your dispencer may be working fine but the one going to the icemaker is not sealing off. Be sure to defrost all the ice out after replacing the inlet valve. And please allow several cycles of your icemaker before it makes its first batch. It can take 2-3 cycles to fill lines and filters depending on your model. Lots of luck to you and please let me know if this helped you. Mca0824@aol.com
Apr 30, 2008 | Refrigerators
Refrigerators Logo
531 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
