I need a repair manual for my mazda 626 1995 specific wiring for stering column and ignition
    Master:
  • 403 Answers
What are you trying tom do
Posted on Mar 26, 2011
1990 ford f-150,,i turn the ignition switch and everything seems fine until you turn it to start,,it just wont do anything,,,i know for a fact that the column internals are good because i checked them
it can be many things the starter, alternator, the grounding wire or bad battery it wouldn't be specifically they ignition switch. It happened to me on a mazda and it was the starter that had gone bad.
Oct 13, 2014 | Ignition System for Ford F-150
1989 ford E 150 wont start after replaceing stering column
You have a main wiring harness that plugs in to the column. Verify this is tight. That harness powers everything, including your ignition. If you removed your ignition and reinserted it into the new column, then verify it is in the correct position and also locked in the correct position. The E-150 could also have the shifter on the column? It is possibly not lined up right and isn't in park. Check shift position and verify it is in park or neutral.
Jul 04, 2014 | Cars & Trucks
Changing ignition on my 02 sunfire
remove the stering columns plastic covers & it will expose the ignition lock
unplug the wiring loom & unbolt it [2 bolts]
they ma be original bolts that the head breaks off so you cant unbolt the [antitheft system]
if they are then you will neeed a steel punch & hammer to start them turning out!
Cheers Rob
Aug 16, 2009 | 2002 Pontiac Sunfire
Someone tried to steal my 2002 mazda b2300
You'll need a new ignition switch. After installation, the dealer can either reprogram your old keys or you can buy a new key and have it programmed.
Jun 11, 2009 | Mazda B2300 Cars & Trucks
How to put on ignition switch on a '88 mazda b2200
If you mean actually replacing the ignition switch on the vehicle with a locking column. You need to do this. Dicconnect the battery, remove the lower panel of the dash if there is any. There is a bolt on the steering column near the fire wall on most vehicles, remove this bolt, it will release the spline on the steering column. Disconnect all wiring going to the column, unbolt the column from the dash support. Remove the column from the truck, on the ignition switch you will see where the two shear bolts screw the assembly together, center punch the center of each bolt. Now drill the bolt with a 1/8" drill about 1/4" to 3/8" deep. Now use a 3/8" drill and drill out the shear head until it comes off the bolt. You can now remove the switch assembly from the column. The new assembly should come with new shear off bolts so when you bolt it in place when tightned they will break off rendering it tamperproof again. Most vehicles are designed like this now to stop theft. Check the column for operation before reinstalling it in the reverse of above. You just want to make sure the key locks and unlocks the column before reinstalling in the vehicle. You may want to do this before you totally tighten the bolts and break them off permanently. Good luck, RAC
Mar 28, 2009 | 1988 Mazda B2200
1994 s-10 replaced ignition actuator gear rack
if you goto any auto parts store you can get a repair manual for your vehical. but i think that the neautral safty switch is no hooked up right.
Mar 20, 2009 | 1994 Chevrolet S-10
Tilt steering doesnt work blows fuses
The wire that supplies a live to your radio, runs from ignition down the steering column. You probably have a chafed wire along that loom, as you tilt the steering, the wire grounds so the accessories fuse/radio fuse blows. Remove the panel under the steering column and/or the shroud around the column and examine the wiring.
Jan 10, 2009 | 1997 Mazda Millenia
Short in steering column wiring
torque bit 20 to remove the air bag bolt in the back cover stering puller stering puller to push plate phillip screw driver that about it pierre
Oct 19, 2008 | 2004 Chevrolet Cavalier
21 people viewed this question
 Grubhead
Grubhead
