Question about Autodesk AutoCAD 2004 for PC
My model wont print, is says "No output devices are configured for this computer. To add a device, go to the autodesk plotter manager to configure an autocad plotter or windows system printer" but when i try to do that it tells me the path i need does not exist or is not a directory
  • 60 Answers
SOURCE: I am trying to install AutoCAD 2004 on my new
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Posted on Jan 03, 2010
  • 236 Answers
SOURCE: i wanna activation key for my autocad autodesk
btjunkie.com
download bittorrent@ first
bittorrent.com
hit me back if you need anymore help
Posted on May 08, 2010
nonontech
  • 4737 Answers
SOURCE: output display configuration
Try changing the display resolution of your system. To do this, follow the instructions below: Right click on the Desktop - Properties - Settings - on the screen resolution, drag the slider to the left or to the right to adjust, and click apply, and check the player before you click Ok. Repeat this steps until it's is playable. I can't help you perfectly since you didn't mention the operating system you are using. Good luck. Thanks for using FixYa.
Posted on Jun 02, 2010
asadjkd
SOURCE: autodesk autocad 2006 activation cade
UHXF HW99 CURY 9945 F8VX
1XEP ZSET
this is my request cde please sand me activation cade
Posted on Aug 15, 2010
  • 3 Answers
SOURCE: Ilegal software needed in prison where I am going to live my life
activation code
Posted on Jan 06, 2013
Hello sir, Windows 7 AutoCAD 2010 HP DeskJet 1280 All the programs on my compute are printing just fine except for my beloved Auto CAD When selecting the printer, a massage comes " this...
if everything else works ok except AutoCAD then the problem is not the printer, it is a broken data connection between AutoCAD & the printer. Sometimes all it takes is to unplug & replug the cable, or restart the pc with printer already connected.
May 03, 2017 | HP DeskJet 1280 InkJet Printer
Tip
How to Add Ringtones on iPhone X?
iPhone X is an all screen phone which was released last November 2017 as part of the celebration of the 10th anniversary of the Apple Company. This phone model has its default ringtones the same as the other mobile phones. Ringtone is a sound comes from a mobile phone when an incoming call receives. On the other hand, some users are looking for unique ringtones on their device so that the default and dull ringtones for calls and messages will change. Actually, we can help you to add ringtones on iPhone X with this tool.
Apowersoft Phone Manager
This is a mobile file manager which is compatible with iOS and Android devices. It enables you to transfer, manage, view and backup files such as music, photos, videos, contacts, messages, app, call logs and many more. Here are the steps on how you can add ringtones on your iPhone X.
  • Head up to your computer's browser and visit Apoweroft Phone Manager page. Download and install the program on your computer.
  • Once the program installed on your computer, launch it.
  • Connect your iPhone X to computer via Lightning Cable. Tap "Trust" button when a window pops up asking if you trust the computer. Your phone will be automatically detected by the tool.
  • Once connected, click the "Music" icon on the program's interface.
  • Click "Import' button and select ringtones from your computer then click "Open" to start adding files to your iPhone X.
  • You can now change ringtones for your device. To do it, simply go to "Settings" > "Sounds" then select ringtones for the text message and voice calls.
Note: All added ringtones will automatically appear on your device.
Aside from that, there are other functions you can use such as screenshot, display phone screen and connect another device at the same time. This tool is very easy to use since it has a user-friendly interface.
Apowersoft Phone Manager Manage Backup Restore iOS and Android Data
on Jan 02, 2018 | Miscellaneous
Tip
How to troubleshoot printer issues?
<p><b>General Printer Troubleshooting:</b><br /> <ul> <li> Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.<br /> <li> Turn it off and on again to reinitialize any internal settings that may have gone astray.<br /> <li> Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge. <br /> <li> Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.<br /> <li> If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.<br /> <li> If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.<br /> <li> If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.<br /> <li> If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.<br /> <li> The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.<br /> <li> If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.<br /> <li> If the Print Screen succeeds, the problem may be with your application or its configuration. For example, your application may be set up to direct output to a file instead of the printer, or you might be directing the output to the wrong communications port.<br /> <li> Try connecting a different printer to this computer or try connecting the printer to a different computer and print a test page. If this printer works when connected to another computer, there may be a problem with the port on your PC. If this printer does not work when connected to another computer, there may be a physical problem with the printer. </li></ul>
on Jan 21, 2011 | Office Equipment & Supplies
I want to put videos and pictures plus music
From the support internet site of Coby you're able to download Coby Media Manager.
You can use this manager for converting and transferring data.
How to get the manager:
Enter cobyusa.com in the address bar of Internet Explorer.
Next select Support in the page top.
From the support site select Manager fix for the MP822: It is the complete software program.
Follow up the steps to download and install Coby Media Manager, matching your operating system.
After installation, run the Manager.
Select Tools > Device Manager... in the page top of the program.
From Devices List, select MP725.
Add >>
OK , to setup the selected player as your Favorite device.
In Device configuration you can setup the synchronization and see the output file formats for the selected model.
Use the Help [F1] function, for how to work with the Manager.
Sep 01, 2010 | Coby MP725Digital Media Player
My coby m600-4g mp3 player is connected to my computer through a usb port how ever my computer is not picking up the device. How do i get my computer to recognize the device as removable media?
You can install Coby Media Manager from the manufacturer.
Go to cobyusa.com
Select Support
Select the download Media Manager fix for MP822
Follow up the installation of Coby Media Manager for the operating system on your computer.
After the installation, run Coby Media Manager.
In Coby Media Manager, In the page top select: Tools > Device Manager...
From the Devices list select the matching MP600 AC or AL version.
Add >>
Select OK to setup the matching player as Favorite device.
In the Device Manager under Configure... or Device Configuration you
can choose between manual or automatic setup for synchronization
and the output file format can be changed.
Apr 23, 2010 | Coby MP-610 MP3 Player
Does the HP DesignJet 1050c plotter have a counter?
This data is printed out on the Service Configuration Print
  1. Load the plotter with media.
  2. When the device is 'Ready' scroll the menu to the Printer setup options and press Enter.
  3. Once in the 'Printer Setup options' menu, use the arrow keys to scroll to 'Utilities', and press Enter.
  4. In the Utilities menu, use the Arrow key to scroll to 'Test Prints' and press Enter.
  5. Use the arrow key to scroll to 'Service Config' and press Enter to print the Service Configuration Print.
You should find the data you are after under the heading of Maintenance on the printout
Good Luck!
Dec 07, 2009 | HP DesignJet 1050c InkJet Printer
Auto CAD 2007 Arabic print
Hello and thank you for using Fixya's services.
You may want to try and un-check mark the box in the plotting section. It will read, mirror image or flip image I believe. These settings can be found under the tools menu or configuration options.
Another suggestion is to check Autodesk's website for updates and/or patches. Make sure you have language updates installed from Microsoft as well.
You can also take advantage of the Autodesk support by capturing a screen shot and sending it to them with explanation of problem. They are very helpful and will answer in less than 48 hours.
One more suggestion would be to check the plotter configurations. The plotter may be set to default to print mirrored text. I am not sure what type of plotter you have but if you let me know, I can assist further.
Nov 08, 2009 | Computers & Internet
Autodesk AutoCAD 2004 for PC Logo
406 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
