Spin dry very noisy only 2 years old - Washing Machines
    Problem Solver:
  • 53 Answers
Spin drum touching on side, Leg spring alignment not clear.
Posted on Mar 26, 2011
Loud squeaking.
To me, I think I am hearing a dry bearing.
However, an old worn out belt can make the same sound!
You could take off the belt and try spinning the pulleys to hear which is noisy, or you could use a mechanic's stethoscope to find out.
A mechanic's stethoscope is a really long screwdriver or metal rod about 2 or 3 feet long that they put on different parts (put the handle end to your ear) to hear the noise each part is making.
If your belt is good, try the alternator bearings.
There is also an idler pulley or maybe 2 that could be noisy.
Be blessed.
Feb 07, 2013 | Cars & Trucks
My washing machine makes a loud noise when it spin dries. what could be the problem? it washes well; the machine does not shake or vibrate during the spin drying; it just makes a loud sound; it never was...
It sounds like the bearings are starting to go.The problem is as it is 6 years old the repair job could be expensive,unless you have an extended warranty.It still might be worth getting a quote off one of your local repair dealerships.
Hope this helps.
May 03, 2010 | AEG Lavamat W1050 Front Load Washer
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Noisy spin cycle
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Jan 15, 2008 | Maytag MAV8557 Top Load Washer
Noisy
it could be the coupler between the motor and the transmission
Jan 13, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Duet washer and Dryer 4 years old
open the bottom access panel , 3 screws on bottom front,
open the filter trap and clean, it will dump some excess water,
you didn't explain the spinning issue well , not spinning fast , noisy, no drainage etc....
Dec 31, 2007 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Noisy spin cycle
Hey ****, what you are hearing is the spin bearing. Maytag redesigned the bearing kit on this washer, there must of been a lot of leaks causing the bearing to go bad. They put out a service flash...TDL-0060-B. New seal and bearing kit, part number12002470. You may want to contact Maytag on this for it could be covered. I know you have 5 years warranty on the transmission and If they change that, they have to use a new seal and bearing. Catriver...post back.
Oct 06, 2006 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
