Question about Watches
My Tempus Fugit grandfather clock stopped working. Every time I swing the pendulum, it stops later on. We moved it from the first floor to the middle of two stair cases. It stopped before we moved it but during the time we moved the clock, the mechanism fell down but not to the floor. It worked again but a few months later, it stopped. It was moved several times because of the rain water leak above the clock. Right now, it stopped.
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Posted on Mar 23, 2009
cmcduncand
  • 714 Answers
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
Posted on Feb 15, 2010
  • 15 Answers
SOURCE: the time and chimes are out of sync for our tempus
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Posted on May 10, 2010
male_28_cam
  • 1555 Answers
SOURCE: we have a seth thomas
1, Wind the clock. If the pendulum still does not swing, check the hands of the clock. If the hands are touching each other, push the hour hand gently toward the clock face. If the hands still touch, gently bend the minute hand away from the clock face.
2. Examine the swing of the pendulum. If it moves, and then stops, or if it swings erratically, the clock is probably off-balance. Gently tilt the clock to one side and restart the pendulum.
Watch the swing of the pendulum. If it stops again or continues to swing erratically, try tilting the clock in the opposite direction. Tilt the clock at various angles, on each side, and front and back, until the pendulum runs smoothly and regularly.
Note the clock position in which the pendulum swings freely. Place a wedge underneath the clock in the place needed to maintain this angle. If a wedge alone will not hold the Seth Thomas grandfather clock in the proper position, try lifting the clock slightly up against the wall.
Use a screwdriver to attach a bracket to the wall at the appropriate position. Additional brackets may be needed depending on the angle required. It may also be necessary to employ a combination of wedges and brackets.
Posted on May 28, 2011
The pendulum on my grandfather clock no longer works .. It is not a problem with batteries . It just no longer moves .
wind the spring up
if is battery operated replace the battery that swings the pendulum
Aug 30, 2017 | The Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    I believe the grandfather clock I was given was over wound by the previous owner. Is there anyway that I can fix this myself so that it is affordable?
    If you have the patience, you could try the following.
    Set the pendulum in motion - this will slowly wind down the mainspring. The clock will probably stop after a few seconds. Set the pendulum swinging again as necessary, and if you're lucky the period that it ticks for will increase each time.
    You will need to be patient and persevere - what you are doing is very gently releasing the tension on the mainspring.
    This is not guaranteed to resolve the problem, but it won't harm the clock or your bank balance to try. Failing that, there is a mechanical fault that is causing it not to wind and you are strongly advised to place it in the hands of a reputable and competent clock repairer.
    Aug 23, 2017 | Watches
    How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
    The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
    Feb 10, 2011 | Watches
    Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
    Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
    Jan 01, 2011 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    The pendulum stopped swinging...the clock and chimes work well
    Hi
    This clock short of needing a full service may simply be out of beat.
    Taken from my web page located at:
    http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
    "HOW TO PUT YOUR CLOCK IN BEAT"
    -Included below is a 10-second sound <snip> of a clock both in and out of beat.
    IN BEAT ////////\\\\ OUT OF BEAT
    · Turn on your sound and click on the clocks above for a sound clip.
    -One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
    -I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
    -As I'm sure we now realize a clock must be in beat but not always level to function properly.
    · Above is the verge with a slip clutch.
    · Often found on Grandfather clocks and requires only a long swing to get it in beat.
    -To get the clock on the right side in beat you would need to push the verge assembly to the left.
    -If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
    R/ David
    Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Watches Logo
    1,385 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
