Question about Exercise & Fitness
Repco fitness Treadmill error E7 - Exercise & Fitness
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Posted on Nov 24, 2011
I have a Sole f63 treadmill and I am getting an E7 error
This is an incline motor issue. Your manual should have the steps to get the treadmill into calibration mode. Follow the steps and the treadmill will calibrate itself. If it fails the calibration then it’s most likely that the incline motor needs to be replaced.
Nov 29, 2017 | Exercise & Fitness
I have an Endurance T10 Treadmill with an error code of E7. Any ideas what I can do?
If you wish to get some details about treadmill error codes and solution ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 27, 2017 | Endurance Exercise & Fitness
What is error e7 in AC motorized treadmills and how to resolve it?
defective system. you may need a new one, you failed to mention make, model, and age of the unit, as well as approximate (estimated) number of hours operating time on it.
all those could be important factors to know before anyone can give good advice.
Mar 08, 2018 | Exercise & Fitness
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Dec 15, 2012 | Exercise & Fitness
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
It keeps flashing E7 and 1300, 1310, and 1320
I tested the elevations motor to see if it had a short. In doing so the motor reset itself and the treadmill went on performing as normal. I had to refer to the repair manual provided by BH on their website and found what the error code E7 meant.
Jan 07, 2010 | Bh Fitness T8 Basic Treadmill
Exercise & Fitness Logo
541 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
