Question about Suspension & Steering for Land Rover Freelander
Hi, I own one Freelander2, 2008, HSE 3.2HP(Runs on gasoline) and I have been listening to a noise whenever I make turns. I went do the Land Rover 's Dealer and the suspension arm has been replaced 02 times on both sides. Last time they even used a "superglue" as an alternative so solve the problem. After a litle awhile the strange sounds returned. How can it be fixed ? Anybody knows something about it ? Is it common on this model ? Thanks, Cesar Martins
  • Land Rover Master
  • 3,018 Answers
What you are hearing is probably a "pop pop pop pop" as you are turning the corner. This is a the sound a ball joint makes when it is dried up and worn out. When you say "super-glue as an alternative" do you mean they super glued the boot together? The boot is the rubber boot encompassing the ball joint. This is not a good practice at all. So it sounds like your tire rod ball joint on that side is completely shot. When this one is replaced make sure to grease the Zerk fitting and all your Zerk fittings with grease. If one greases all the Zerk fittings on their vehicle and the boot never ruptures then that joint should never go bad again. If you have never done this before then I will suggest to have a shop replace that tire rod and you may need an alignment afterwards too. As for is it common with your model, well, so much with the newer vehicles the manufacture makes "sealed" ball joints. The problem is not with the model so much as the problem with many companies doing this. With a "sealed" ball joint there is nothing to grease. So when they go bad the only option is replacement and with no fitting they will go bad eventually. Once a replacement is on then one needs to keep it greased or it too will go bad in time.
Regards, Tony
Posted on Mar 26, 2011
2004 land rover range rover hse transmission is overheating and drives like it's in sand or mud. Also have air suspension inactive warnings along wIth HDC inactive suspension light dosent even lightup
check that you are not in 4 x 4 settings on hard surface as that loads up the transmission making it work harder
that it turn can over heat the transmission oil
check for correct oil level in transmission as too much oil or not enough will also heat oil
take it to an accredited service center that has experience on your make of vehicle for a diagnosis of all problems
Nov 30, 2016 | BMW Cars & Trucks
HSE. What caused power running boards to quit working recently?
Water in the electrics seems the most likely cause. Dealer job to fix unless you are very handy with electrics.
Jan 27, 2016 | 2007 Land Rover Rover Range
Squeeky noise from Range rover 2006 HSE
Likely, that is the sound of your "wear indicators" because your brake pads are worn.
Jul 18, 2014 | 2006 Land Rover Range Rover
Hi last week a high pitched noise started on my 02 hse. the noise seems to becoming from the rear of the vehicle, it is a continuous noise, I recently had the fuel pump replaced, could this have anything...
When you turn the key to position II, does the noise start then? This would be the fuel pump. If it is making a noticeable noise while driving, then you should get whoever fitted it to check it over. If it failed, your car would stop immediately.
Oct 08, 2013 | Land Rover Cars & Trucks
I have a squeaking noise coming from the rear of my 06 range rover hse what could it be
Rear suspension bushings will squeak, Dealers will want to replace them all, Give them a good soaking with a rubber lubricant and they will stop making noise, I use Ruglyde, it is a rubber lubricant for mounting tires and works very well for this squeak
Dec 11, 2012 | Land Rover Range Rover Cars & Trucks
Why won't my '99 Range Rover HSE start?
can you here your fuel pump running.if so go to your injection pipe and press valveto see if there is fuel getting to it
Jul 13, 2012 | 1999 Land Rover Range Rover
2003 Range Rover HSE shut off while going down the road. The battery light came on about 30 miles before.
Your alternator has went out. The engine shut off because it drained the battery and had no power left to run it.
Jul 19, 2011 | 2003 Land Rover Range Rover
Diff leaking oil making noise can i get secound hand one ? how much to get it repared
if the dif is making noise, its probably bearing fatigue, due to lack of oil (leak) you can buy a second hand one at a salvage yard, check your local salvage yards, if that doesnt work, try a parts locater service.
Oct 27, 2009 | 2004 Land Rover FreeLander
Suspension & Steering for Land Rover Freelander Logo
50 people viewed this question
Top Land Rover Vehicle Parts & Accessories Experts
Bill Boyd
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Land Rover Vehicle Part and Accessory Expert? Answer questions, earn points and help others
