Question about Bosch Microwave Ovens
Hi, I have a HMT 35M 653B microwave oven that will not start. A red illuminated clock shown in brackets above the time. can you help please?
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
mikedem7
  • 25 Answers
SOURCE: Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
jyackle5
  • 8197 Answers
SOURCE: how do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Posted on Jan 10, 2009
SOURCE: Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: JVM1540 Above the oven microwave is not heating anymore
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgf
Posted on Sep 30, 2010
RHM2048SS. There is a red illuminated clock in the RH corner of the control panel above the time read out. This is on continually. Should it be?
It should be there unless you are running a program (according to the owners manual for that oven).
Manualslib.com has more info on it.
Jun 03, 2016 | In Microwave Ovens
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
Hi I am having problems setting the clock on my cooker could you please help thaankyou
HELLO.
solution on setting your microwave clock is explained below.
This is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
MY 5 YEAR OLD BOSCH INNOWAVE BUILT IN MICROWAVE HMT 8656 HAS JUST DIED. WHAT IS THE LATEST MICROWAVE TO REPLACE IT
Here`s a little fact about microwave`s, they are not healthy - http://rense.com/general70/microwaved.htm
We threw ours out, food taste much better cooked on the stove, oven or grill.
Apr 15, 2011 | Bosch HMT8625GB Microwave Oven
Microwave won't come out of start up mode. Clock flashing 00:00 and interior light on. Just moved house, owned micro for 3 years, lost manual in move. Please help.
could be a broken door hook; defective door microswitch or the microswitch bracket itself. the door just may need adjustment; as many people lift microvave by the bottom of the door; which is a no-no.
Aug 24, 2010 | Sharp R-654 Convection/Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Cant set the clock
    hi
    In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
    Clock > time digits > Clock
    Clock > Clear > time digits > Clock
    Clock > time digits > Start
    If that doesn't work, please reply back with your brand and full model number.
    All the best and do rate this answer if u r satisfied.
    thankyou
    May 10, 2009 | Microwave Ovens
    Control pad does not repond
    hi
    i think the timer has to be reset,,and make a hard reset..
    than k you............
    Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
    Setting the clock on Sharp Microwave Oven
    Normally it's
    Clock > time numbers > Clock
    or
    Clock > time numbers > Start
    Sometimes it's
    Clock > (1 or 2) > time numbers > Clock
    or
    Clock > (1 or 2) > time numbers > Start
    If this doesn't work, please reply back with your model number.
    Mar 08, 2008 | Microwave Ovens
    Setting time on sharp microwave
    Normally it's
    or
    Sometimes it's
    or
    Microwave Ovens Logo
    134 people viewed this question
    Top Bosch Microwave Ovens Experts
    William Miller
    William Miller
    Oscar Netto
    Oscar Netto
    Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
