Question about Samsung Televison & Video
I have a Samsung TV Model TXR3079WHXAA and the screen flashes or splashes from time to time.I can still see the picture.
  • 8thomas_loui Mar 26, 2011
    I would like to see what another expert thinks about the splashing or flashing screen.
    The sound does not change when the screen flashes.The TV is connected to a cable box and a DVD player and it does flash.The flashing occur periodically.
    Top Expert:
  • Samsung Master
  • 75,471 Answers
Hello
Will you please give me some more details of your Samsung TVs fault. When the screen flashes, does sound output distrorts with it? Will this flashes occur, even when it is connected to other video sources, like DVD, CD etc? Does this occurs periodically, ie, at regular interval of time? Please provide these details to me by Fixya. OK.
Posted on Mar 26, 2011
  • The Knight
    The Knight Mar 26, 2011
    Please check all the plugin connections for tight contacts, and have no loose fittings. The fault is due to intermittent signal input failure. If the TV has the fault, it will show it at regular interval of time. Check the cable boxs' input connection to which the cable is connected to it, and all other plugh in connections. If the fault is due to the internal loose contact inside the TV, it should show, when you hit the TV gently wit your palm. do it and check this first. If there is any loose soldering or loose contact, you can detect by this way.
    If the fault still perists, just retune your TV as per its user manual. OK.
    Genius:
  • 1,112 Answers
Hi:
Have the power supply checked for bludging capacitors also check the inverters as well there a r usually two of them located on the inverters that should be checked. If you find them buldging replace with same voltage and capactance rating. But you main problem I believe is on your power supply.
Horizontal lines in Samsung led tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 18, 2017 | Samsung Televison & Video
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Samsung 50 Smart TV...Sound but no picture...Fuse? or Inverter? or what?
Look at the picture up close and with a flash light. If you can see images then it is the inverter
Sep 09, 2015 | Samsung Televison & Video
When power is turned on, splash screen comes on, then no picture. Screen flickers and then goes to black.
Hi Randy,
You have not mentioned the brand and model no. of your tv. Recently I repaired a Samsung smart LED tv for the same fault. One of the Light Emitting Diodes ie. led in the back lights was not functioning. The fault is repairable if you find someone who can open the led panel and repair it.
Good Luck
Apr 08, 2015 | Televison & Video
WHAT CAUSES THIS PROBLEM
defecctive panel,panel need to be replace,bad tab bonding,not econmical to repair
Oct 02, 2014 | Samsung Televison & Video
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 12, 2017 | Televison & Video
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 13, 2014 | Samsung UN22D5000NFXZA 22 In Led Hdtv...
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
