Question about Bosch AquaStar 2400ES-NG
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
    Top Expert:
  • Bosch Master
  • 8,688 Answers
Some if not enough water flow wont go on all the way see if pressure adjust
Posted on Dec 18, 2017
    Scholar:
  • 130 Answers
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Posted on Mar 26, 2011
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
On demand hot water heater gets cold for a short while during showers.
Check for crossover.
Bad single-handle faucet cartridge causes cold water to enter hot pipe, so hot never arrives and tankless does not run consistAntly
http://waterheatertimer.org/Crossover.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 13, 2013 | Bosch AquaStar 2400ES-NG
Bosch aquastar wont get hot
1) If tankless is not showing error code, the problem might be single-handled faucet cartridge:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
2) Catch up on maintenance, such as cleaning combustion parts, have gas pressure checked, etc.
Feb 20, 2013 | Bosch AquaStar Natural Gas Tankless Water...
Once in a while after burner has been on and shower has been on for a while, the burner shuts down and pilot flutters, then pilot comes back on good but no burner .eventualy burner comes back on. if i turn...
Probably the burner and parts need to be cleaned yearly as recommended in most gas water heater manuals. Both tank and tankless today recommend same.
Open following link for Bosch troubleshoot resources:
Jun 20, 2011 | Bosch AquaStar Natural Gas Tankless Water...
I have a aqua star 125 bng-l ser 9650617 the only way i can get water hot is by turning on the shower annd the bathroom tap on?
These type of heaters require a minimum amount of water flow. If your showerhead is the most common flow-restricting type then perhaps it is not permitting the minimum amout of gallons per minute to flow through the unit for it to remain engaged. You might have to try removing the flow restrictor :(
Feb 04, 2011 | Bosch AquaStar Natural Gas Tankless Water...
My bosch aquastar 2400 shuts off sometimes during a shower
It sounds like you have a well. Make sure the water pressure does not dip below 30PSI. Otherwise, the gas pipe or the CO2 levels need to be adjusted by a qualified gas technician.
Apr 11, 2010 | Bosch AquaStar 2400ES-NG
I had our 1600ng Bosch water heater installed a month ago during warmer weather. It is not providing very hot showers. I use all hot no cold. how can io get more heat
on the front of the water heater down at the bottom there is a thermostat (usualy a blue knob) turning it clockwise will increase the tempature of your water
(good Luck)
Oct 12, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
Gas tankless water heater turns off during shower
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Feb 23, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water temperature varies while useing the hot water during a normal shower. jg
Try this before replacing the shower diverter valve.
If this problem is isolated to the shower only, then I would suggest that the shower diverter valve is equipped with an "Anti-scald" safety feature that can not be adjusted, however the temperature regulator/thermostat on the water heater can be adjusted to a lower temperature so as to not activate the the "Anti-scald".
Feb 20, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar 2400ES-NG  Logo
262 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
