Question about Cameras
Is it possible to fix the latch on the opening to the film casing on this camera? It is 22 years old, and the local camera shop near my home said they don't make the part for it anymore. Thank you.
    Scholar:
  • 80 Answers
Since it would be difficult to acquire parts to fix the latch of your camera, I suggest that you improvise in a way that it would keep the latch firmly closed and it would be easy to open when you need to remove the film. One suggestion is to buy Velcro in a hardware store and place it near the camera's latch to securely keep it shut.
Hope this helps.
Posted on Mar 26, 2011
Sensor problem what is the cost to fix
Given the age of the camera (it's at least three generations old), it will almost certainly cost more to fix it than to replace it with a current, more capable camera. The actual cost will depend on how much your local shop charges for labor and the availability of parts for a camera nearly five years old.
Dec 10, 2012 | Olympus FE-340 Digital Camera
Who can repair the film door latch?
Any camera shop can send this out for repair or to get an estimate. It may not be repairable due to parts not being available.
Feb 01, 2012 | Nikon N75 35mm SLR Camera
I put a fresh new pack of film into my Fuji film instax 210 camera but only used it to take two pictures. The next day when I tried to take a picture, it came out completely white. Why is that? It is very...
Completely white photos on an Instax, or any instant camera means the film has been exposed somehow. Check to be sure the film door is completely closed, and latched properly. If it is, it's possible, though unlikely, that your camera's shutter is stuck open. It'd be easy to check, simply look at the front of your camera into the lens, and see if you see any mechanical bits, now take a picture and see if you see any of them move - movement means working, no movement means not. If the entire camera back opens (I'm not sure if it does) you can also open it and do the same thing, looking to see if you see light through the camera when you're looking through the lens but not taking a picture - if you do the lense is stuck open. This, however, would require removing and wasting whatever film is remaining in it right now.
Aug 30, 2011 | FUJIFILM Instax 210 Film Camera
My brother's Fuji Discovery 1000 35mm Camera met with a small accident. The latch on the cover is broken. I don't know how old the camera is, but would like to know if it can be fixed, and if so, what is...
Parts are no longer available, and like almost all 35mm compact cameras (and many SLR's), your brother's camera is utterly worthless so repairs are totally uneconomic to repair unless you can fabricate a replacement latch yourselves.
Although this may sound gloomy, it's not. The silver lining is that you can easily find a similar or better model on your local FreeCycle or Freegle groups for zilch. There are millions of perfectly good 35mm film cameras lying unused at the back of peoples cupboards and drawers and the majority of owners know they're near worthless so haven't even invested in the replacement batteries that many need.
May 27, 2010 | Fuji Discovery 1000 35mm Point and Shoot...
Camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
Oct 04, 2009 | Nikon N6006 35mm SLR Camera
Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Sep 06, 2008 | Canon T70 35mm SLR Camera
Film is not developing
It's hard to tell without looking at the film itself, and it would help to know what type of film you are using (black and white? color?). My guess would be a light leak. If the film is exposed to any light, that results in a black picture, possibly blotches of color. Either you opened the camera before you rolled the film back into the canister (unlikely), or your camera is responsible for the light leak, in which case, you will have to bring it to a repair shop.
Mar 24, 2008 | Pentax ZX-50 35mm SLR Camera
Removing old film putting in new
The latch to open should be on the side of the camera. The bottom front opens to allow you to remove the film pack
Feb 20, 2008 | Polaroid One Instant Camera
My crystal ball tells me that you are referring to you vintage 1939 Pentax SLR camera! Is that correct?
May 12, 2017 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Film doesn't load
I have traced and rectified the problem I posted Nov 04 2007.The electrical contacts on the door latch were missaligned so I just realigned and problem solved.
Dec 22, 2006 | Fuji Endeavor 400ix APS Point and Shoot...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
