Question about Samsung ML 1610 Laser Printer
I put a new toner Cartidge but have the red light on and i am not able to print
    Problem Solver:
  • 10 Answers
Hi, without buying new cartridge we solve the cartridge problem.9916076261
Posted on Mar 26, 2011
Fax machine print light
When you see light print it can be from a few things. This is basically a laser printer with a fax machine so the same problems exist in both. The most common cause by far is simply low toner. If you take out the toner cartidge and gentl shake it side to side then put it back in. Now try printing again. This should be much darker. This may only last a few dozen pages (but can go a quite a bit more if you are lucky) but it shows you that you need to get a new toner cartridge. The other causes can be a image setting in the fax. In the control panel it will show you a setting for how dark it will print. Normally it is in the middle of the range. The last common thing is a fusor wire. This normally shows up as a error first but it can slowly fail. The fusor is the heater that bonds the toner to the paper. If it doesn't get hot enough then not all the toner sticks and you get light printing.
Normally the problem is low toner.
Jan 10, 2012 | Panasonic KX-FL511 Plain Paper Laser Fax
My samsung ML 1610 printer, printing very light, even though the toner is brand new.pls someone solve this problem thanks
There's a button on the top called "toner saver". when you press this is prints light to save toner. Press this once to turn "toner saver" off and print normally..
Aug 17, 2009 | Samsung ML 1610 Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
The print quality isn't good. there are lines in between with the red colors on pages.
Run the printer cleaning utility, replace the toner, if printer is inkjet put cartidge and wipe down the exit nozzels
Mar 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Dirty Copies
clean the ink box from printer where the cartidge park
Mar 20, 2008 | HP LaserJet 1012 Printer
TONER EMPTY MSG
1-remove power from fax.
2-clean contact points in toner cartidge and the contact in fax which it make contact together.
3-knock above toner cartidge many times.
4-move it in horizontal direction from left to right many times.
Feb 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Samsung ML 1610 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
