Question about Apex Digital AT2002S 20" TV
Its lock and i dont have the remote what to do help
    Top Expert:
  • Apex Digital Master
  • 75,767 Answers
Hello
Without its original remote control it is immpossibel to open its lock. Just try to get it from one for the same model amoung your relatives or from others, just to open the lock of your TV. If you can collect one, do the following with it.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Posted on Mar 26, 2011
Hello, I have a question, how to do yo reprogram the remote control on a 2004 GMC Yukon?
CLOSE ALL DOORS INSERT KEY INTO IGNITION.DO NOT TURN THE IGNITION SWITCH.PRESS AND HOLD DOOR LOCK SWITCH IN THE UNLOCK POSITION.SWITCH THE IGNITION ON OFF ON OFF.RELEASE DOOR LOCK SWITCH.SYSTEM SHOULD NOW LOCK AND UNLOCK VECHICLE INDICATING PROGRAMMING MODE ACTIVATED.PROCEED AS FOLLOWS.NOTE EXISTING REMOTE TRANSMITTER MEMORY POSITIONS WILL BE OVERWRITTEN.PRESS AND HOLD LOCK AND UNLOCK BUTTONS ON THE FIRST REMOTE TRANSMITTER FOR 15 SECONDS.SYSTEM WILL LOCK AND UNLOCK VECHICLE INDICATING REMOTE TRANSMITTER PROGRAMMED.REPEAT ABOVE PROCEDURE FOR EACH REMOTE TRANSMITTER.IF THIS DONT HELP DEALERSHIP HAS TO REPROGRAM REMOTE.
Aug 09, 2010 | 2004 GMC Yukon
When I lock my key sedona 2005EX, with remote, dont hear the beep
Press the lock button once to lock then press and hold to beep the horn. Kind of have to press twice.
Mar 07, 2010 | 2003 Kia Sedona
I just bought a car that came with two Pursuit PROOE4BS remote I can only get the remote starter to work but after the car starts2c if I enter and depress the brake2c the car will turn off Also I can27t...
if you enter the car after you used remote starter,dont depress your brake.you need to put your key(insert) into your igniton barrel
and turn it in to ON possition(dont crank the starter) now you can depress your brake to cancel the remote start.and your door lock and trunk maybe the installer didnt connect the wiring from remote starter to your car...
Feb 09, 2010 | 2004 Lexus ES 330
Remote locked not working steering locked wont open
hi,try your spare key,also check your fuse 8,9,14,35 those fuse are for remote control,anti-theft,maybe help for you,ty
Apr 13, 2009 | 1998 Mercedes-Benz C-Class
Remote door locks dont work unless van is on and
for the stereo i would suspect a loose wire just follow power wires back maybe it not earthing properly hope this helps regards Jim
Mar 29, 2009 | 1997 Dodge Caravan
Television Locked.
My Durabrand DBTV1020 is locked. I dont have a manual or remote. HHow do I unlock it?
May 19, 2008 | Televison & Video
Unlock Hyundai TV
motimoti 's solution worked. Thanks.
By the way, how do you find the solution ?
Apr 21, 2008 | Televison & Video
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it on...no other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
Child Lock
have you tried pressing menu and searching for parental controls secction or even settings, maybe could help. if not get a universal remote which does evrything from dvd,vcr,tv all in one. all u do is set a code for each. its 5-20 bucks availabe anywhere
Jan 08, 2008 | One For All URC4220 Remote Control
Apex Digital AT2002S 20" TV Logo
79 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
