Question about HP DeskJet F380 All-In-One Printer
I installed HP web print, restarted, and now windows will not even start - even with the windows disk. I think I might lose everything! My windows disk cannot find a restore point. I am running windows 7.
  • 356 Answers
First try unplugging the printer. Sometimes (very rarely) USB devices can cause the system to act abnormally. When booting up, keep pressing the F8 key to enter safe mode. If it lets you enter safe mode, try using a restore point from before when you set up the printer.
If you can't get into safe mode, you can still reset the computer to factory settings from a recovery partition (comes with most Windows 7 models) or recovery discs.
If you have important data, you can still recover it by either pulling out the hard drive and putting it in an external cage to copy to another computer, or by using a live Linux disc to boot your computer and copy the data to a flash drive, DVDs, hard drive, etc.
To boot from the recovery partition varies by model, but is often Alt+F10 when booting and follow the instructions.
Posted on Mar 26, 2011
Hp deskjet 1010 won't print with only black cartridge installed. They tell me it will and then suggest I buy a color cartridge anyway. I need to print now. How can I do this?
I am sorry to hear that you cannot get the Deskjet 1010 to print on your Windows XP computer. I will try my best to help you resolve this issue.
I recommend using this document forUSB Printer Installation Troubleshooting. After doing the disk clean up, I recommend doing a re-register of the windows installer.
To Re-register Windows Installer
Click Start, click Run , type MSIEXEC /UNREGISTER , and then click OK .
NOTE:Even if you do this correctly, it might look like nothing happens, but it does.
Click Start, and then click Run .
In the Run window, type MSIEXEC /REGSERVER , and then click OK .
Then follow the rest of the steps in order. Be sure to restart after installing before trying to print.
I hope this information helps, please let me know how it goes. Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 19, 2014 | HP Deskjet 3845 InkJet Printer
My printer won't print.
click start click on run or the keyboard shortcut is the windows key and the letter r at the same time
a run box appears click the browse button
click my computer and select the disk drive the software cd is in. look for a folder that is titled util or utility, open it and open the ccc folder. from there select uninstall l3
make sure your usb cable is disconnected
click okay to run the uninstall... it will begin to remove the hp software and drivers. let the pc restart, upon restart run a disk clean up
once the disk clean up is completed re try the install with the usb cable still disconnected untill the sw advises you to connect the device.
that should install the drivers cleanly and you should be able to print and scan
Mar 29, 2010 | HP Photosmart C4580 All-in-One InkJet...
HB Deskjet 6940 Won't Print - Windows 7
To solve this problem do the following steps :
Start -> Run -> Type services.msc -> in the service consol find the print spooler service and check is it started or not if it is start then right click on print spooler and click on restart.
If the print spooler service is stop the right click on print spooler then click on the properties, in properties click on start.
Your problem should be resolve.
Regards
Ashly
Feb 04, 2010 | HP Deskjet 6940 InkJet Printer
HP Officejet J4580 All-in-one SerialNumberJob
open command prompt and give following commands
net stop spooler
net start spooler
repeat 34 times restart computer
Dec 16, 2009 | HP OfficeJet J4580 All-In-One Laser...
Can't reinstall printer- ''print spooler is not working''
If you have the windows disk for it , Save everything important to disks.  Put WIndows  disk into machine and tell it to install. It will find you version and ask if you wish to repair it, Say yes.   If you have Xp pro just "Restore" computer to the date before the problem started. If you have neither one. Save you work and then reinstall everything using your backup disks.
Mar 18, 2009 | HP Computers & Internet
HP 1315xi all in one printer scanner copier config problem
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
Dec 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP printer 1200 cannot access Hp director
I had to redo my whole computer because of virus. when i reinstalled windows xp my hewlett-pachard psc 1210 will print. I get a message that says it is not installed and I have tried everything to get it to work. no disk i even install a driver but still wont work help please
Oct 24, 2008 | HP Office Equipment & Supplies
Unable to print from Internet Explorer
If you are using a MAC try this page -> http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00242727&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN If you are using anything else the following may (or may not) be of some use: Nothing prints: Verify the correct print driver is being selected. Print by selecting File then Print. The current selected printer should be listed in the Print dialog box. Select the correct printer if the wrong one is selected. * Check the print driver Properties to verify it has not been set to offline. * Try printing from another program to verify the printer is functioning correctly. If other programs can be printed from, there is a problem with the Web browser. Try the remaining steps, and then contact the browser vendor if necessary. * Restart the computer and try printing again. System resources may have become low or a task required to print may have died. Restarting the computer should correct these issues. * Install a universal Microsoft ®) printer driver that is compatible with the HP all-in-one, and then select the universal Microsoft printer driver to print from the Internet. To install a universal Microsoft printer driver, follow the steps (these may vary slightly based on the version of Windows in use) below: NOTE: The Windows diskettes or CD-ROM may be required to install a universal Microsoft printer driver. 1. From the Windows Desktop, select Start , Settings , and Printers . 2. Double-click Add Printer . 3. Select Next on the first Add Printer Wizard window if one appears in this version of Windows. 4. If the option for Local or Network printer appears, select Local and then select Next . 5. Under the Manufacturers list, select HP . Under the Printers list, select the HP Deskjet 855c for newer models, or the Deskjet 550c printer driver for older models. Select Next . 6. Select the LPT1: Printer Port for parallel installations, or the DOT4_00x port for USB installations, and then click Next . 7. Select No so the universal printer driver will not be the default printer, and then click Next . 8. When prompted to print a test page, click No , and then click Finish . Insert the Windows disk if prompted. 9. Before using the universal driver, it may be necessary to shut down the HP all-in-one software. Do this by right-clicking the HP all-in-one printer icon next to the time in the lower right corner of the screen, and then click the Close (or similar) option. 10. Print from the Web browser by selecting File , and then Print. 11. Select the Universal print driver in the Print dialog box before printing. Let us know how you get on
Sep 19, 2007 | HP Officejet 6310 All-In-One InkJet...
Will not boot up!!!!
If you have your Windows installation disk then you need tp press 'R' for repair instead of a full installation. This will repair all the system files and you will not lose any documents or settings. But I think maybe you have a bad sector on your hard drive, so when you get up and running go to your HDD manufacturer web site for a diagnosis and repair.
Nov 06, 2006 | E-Machines T3092 PC Desktop
HP DeskJet F380 All-In-One Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
