Question about ASUS Computers & Internet
Shut down when working on battery but now it won't charge or turn on or anything. ??
    Novelist:
  • 107 Answers
Remove the battery and all other peripherals connected. Then press and hold the power button for around 15 seconds. Put everything back in and plug the adapter then power the computer on.
Hope this work. Goodluck!
Posted on Mar 26, 2011
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
Will no turn on & yes it is charged
unplug it and take the large battery out of it. also make sure that no cd or dvd disk is in it and also UNPLUG THE PRINTER AND ANYTHING ELSE TO IT.. NOW PLUG IN THE POWER SUPPLY ONLY AND TURN IT ON. IF IT COMES ON AND WINDOWS COMES UP THEN SHUT IT COMPLETELY DOWN AGAIN, UNPLUG IT AND PUT THE BATTERY BACK IN. NOW TURN IT BACK ON. IF IT WORKS SHUT IT DOWN AGAIN AND PLUG THE POWER SUPPLY BACK IN. NOW TRY IT AGAIN. IF IT WORKS NOW, ONE AT A TIME, PLUG PRINTER IN AND TURN ON. DO THE SAME WITH ANYTHING ELSE THAT NEEDS TO BE PLUGGED IN. GOOD LUCK.
LAPTOP WON'T COME ON
Oct 29, 2015 | Computers & Internet
Laptop shuts down when using battery
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 31, 2012 | Compaq Presario Notebook
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
VISTA PC DOES NOT STAT laptop vista battery went down to 10% Vista was shut down and was connected to power supply try several times to start the pc but it just does not start if pc is shut does the...
The battery continues to charge if the computer is off. The computer probably won't turn on because the battery is so low. It might not be charging because the power cord might not be plugged into a wall plug that is on. The plug might be on a switch. Find a plug that you know for sure that is on then plug it in there and try again.
Jul 29, 2011 | Computers & Internet
My motorola cliq xt shut down and it won't turn back on even if it charges for a whole day
Yo! that has got to be a battery problem. i will advice you buy another battery and charge for at least 3hours before first use. thanks
Jul 29, 2011 | Motorola Mobility CLIQ XT (2 GB) Cell...
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
My HP laptop screen will not do anything. The first time this happened, I was in the middle of something and the screen suddenly became a bunch of black and white random-ness. I shut it down, and tried...
Perform the following:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If turned on, shut down the Notebook, insert the Battery and turn it on again. That's it.
Cause:
With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
Performing above procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
Aug 22, 2010 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
