I have a hp laptop its 3 days old and it says its plugged in but not charging so i got a friends cord and it said the same thing,but when i got it the 1st day it charged fine now its at 95% and not charging
  • 62 Answers
- clean the battery contact points (you can use a rubber eraser then wipe it clean with a piece of cloth afterwards)
- try to power on your laptop using just the AC adapter with the battery removed ( if the computer powers on with just the AC connected then you need to get the battery replaced, if it doesnt power on then the problem would be with the motherboard)
Posted on Mar 26, 2011
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Nov 19, 2010 | HP Computers & Internet
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Nov 19, 2010 | Computers & Internet
My HP G60 is saying plugged in not charging its only 4 months old
Its a very common problem in hp laptops. When the laptop is very overheated it automatically stops battery charging. I had same problem, i consulted hp service center. They made a BIOS update and suggested me to use Laptop Cooler(Heat pad) and my problem was solved.
Also i mostly keep my laptop in Power Saver Mode to keep it cool.
Hope this will help.....cheers:)
Sep 25, 2010 | HP G60-120US Laptop
HP dv7 simply stopped turning on. worked great
What you would want to try is to remove the battery and see if pluging in the power cord will power the laptop alone. All laptops have this capability and this shouldnt be an issue.
But by testing this and seeing if it DOESN'T work then that means there could be one of two things. Your AC power adapter is defective and should be replaced with one that is compatible with your system or that your connection jack is either loose on the inside or broken completely.
However I would stick with trying the cord first before trying to resoder the joint inside the system. I'd leave that to a pro, going back to the battery if you leave it out for a day that should give it plenty of time to discharge any energy it may have in it and you can plug it back into the laptop to try and charge it again either with the same AC power adapter or a new one. If the battery wont hold a charge and you know it isn't because the jack is loose or the AC power adapter isnt defective then you now know you need to replace the battery. You can google compatible batteries and power adapters online or search specific places like Newegg.com or Amazon.
Hope this gives you a better understanding of what may need to be done to fix this!!
check me out at http://ctrlr4repair.webs.com
May 06, 2010 | HP Pavilion dv7-1020us Notebook
Laptop wont recharge the battery
Even though you battery appears A OK, it most probably isn't, all one can do is check the power adapter, by replacement, OR trying another one, from some friendly soul, ... and/or replacing the battery,the same way...
Feb 21, 2010 | Computers & Internet
GOOD DAY TO YOU, I HAVE A PROBLEM WITH MY HP LAPTOP, USING A PLUGGED IN POWER CORD COULD'NT CHARGE MY BATTERY, I REMOVED THE BATTERY AND NO POWER COMING IN THE SYSTEM, WHAT COULD BE THE PROBLEM
Hi there, if charged battery on the power of laptop is fine and not have any problem with your laptop. Your power cord may damaged. Please visit a electronis repair center and test the power code. 90 % chance of adapter damaged.
Thanks.
Feb 10, 2010 | HP Pavilion DV6500T Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
My HP laptop is not getting charged and neither it is taking the direct power.
most likely somthing is wrong...
1)bad powersupply
2)internaly broken power cord
3)broken plug within laptop.
--try another battery from a friend
or
--try another power supply at a computer repair shop.
usually shops (smaller ones)have both of these on-hand for troubleshooting!
good luck!
Dec 18, 2008 | Computers & Internet
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
