Question about Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD)
Have just installed a new seagate 250GB HD in my laptop, the original HD is running hot and crashes. I have to install XP pro from scratch. As the XP CD loads it promts me with "Can not find Hard drive" I have gone into the Bios to see if is reconized there though this Bios does not have that entry. Do I need to load the drives some how? Rgds Larry
    Guru:
  • 433 Answers
Tell us lap spesification plz
Posted on Mar 26, 2011
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
The HD on my Toshiba A135-S4827 crashed. I bought
I see a couple of possibilities here.
  1. The replacement drive is not the same size as the original and the wizard is looking for a drive that size.
  2. There is also a possibility that the error is causes by bad RAM (0A-0543-0000 is a read write error) if you have more than one RAM module try the wizard with one module at a time, see if error is isolated to one or the other module or slot
  3. The Restore CD is dirty/scratched of has a flaw in the original write
  4. The optical drive is defective or dirty
So things you can try:
  1. Clean the media you are trying to restore from.
  2. Clean the optical drive with a drive cleaning CD.
  3. Swap Ram as suggested, replace defective if necessary (OS install is about most RAM intensive process you run on a system)
  4. Try a manual Windows install from a Windows CD not a image restore cd
  5. Try a drive the same size as the original
Oct 21, 2009 | Computers & Internet
System crashes and i have to reformat after installing msn premium software on new 64 bit vista laptop
you can downgrade to 32bit. you would have to reinstall windows using a 32bit cd. i would recommend it you wont see much of a difference. all programs where originally made for 32 bit. the only difference between the two is that 64bit supports more ram. like xp pro; 32bit will recognize 3.25gb as ram even if you have 4gb installed but other than that not much difference. personally i dont like any 64bit systems nor vista... but with 32bit you will be able to run a wider range of programs with no problem
Apr 16, 2009 | Computers & Internet
I installed a new hard drive and crashed
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
Mar 29, 2017 | Seagate 250GB Barracuda 7200.10 ATA-100...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Well I'm one of you guys so you can bet I was confused, this is a computer problem installing XP SP3 on my PC.
clean install ............. floppy... fdisk deleting all partitions first.... and then making a partition of the whole disk.. then formatting.... then do the install and of course ntfs.... and see how that goes
Robert
Sep 01, 2008 | Intel Motherboard
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Original boot discs
I'm afraid, you can't install XP home over XP Pro; it could be done the other way around. you'll have to  backup your important files then format your drive and restart from scratch.
if you have 2 partitionon in your HD e.g C: and D:
you can copy all your important files in the D:\ drive and just format and install XP home in the C:\ drive.
Oct 28, 2007 | Acer Aspire 3000 Notebook
Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD) Logo
175 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
