Question about Canon PowerShot A480 Digital Camera
Camera is telling me the memory card is locked
  • 356 Answers
Make sure the memory card's slide lock is not set in the lock position. See: http://www.samsung.com/us/system/support/content/2008/04/07/h621/Card%20locked2.jpg
if you're unsure about the memory card's lock.
Please leave feedback if this was helpful.
Posted on Mar 26, 2011
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
I insert a memory card its tell me memory full but can't see the pictures from the memory card. how do I get the memory card to read?
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Vivitar ViviCam 8025 Digital Camera
When i take a picture it tells me that the memory is full and i have installed a new memory card. The camera is new
I will assume that this camera is using a SD card as there is no make or model shown. All new memory cards need to be formatted to the camera so the camera can read the card. Also SD cards have a lock on the side it's a little sliding switch that can be very easily pushed to the lock side while installing the memory card here is a diagram of the lock and unlock position of this card.
Formatting a card must be done in the camera the memory card is being used in your owners manual may refer to formatting as initializing
Dec 30, 2010 | Cameras
Canon IXUS 95 IS gives me a report: card locked, while the card is not locked; gives me a report; memory card error please tell me what is wrong?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out (note, this is not the problem with your newer model camera). Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 15, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
The camera tells me the memory card is locked!
If it is an SD card then there is a small slider to lock and unlock the card on the side
Apr 25, 2010 | Praktica SlimPix Digital Camera
When I insert a new memory card into my Z730 it tells me "memory card must be formatted" but it will not format. The memory card that is currently in the camera works fine!
Hello. Some of these memory cards have a small lock slide on the perimeter. Check yours to see if in fact, it is in the lock position which would prevent you from formatting. Formatting erases everything from the card so the lock is a protection.
please rate my answer as very helpful.. thanks. J.
Mar 29, 2010 | Kodak EasyShare Z730 Digital Camera
Camera is saying "Memory card is locked. Slide lock to "write" position."
If you remove the card from the camera, there is a little switch on the SD Card. There is typically a label that shows which direction is locked. If not, switch it to the opposite side. This should solve the problem. Otherwise, there could be a problem with your card. I hope this solves the problem.
May 17, 2009 | Nikon D40x Digital Camera
Memory is locked on the camera
ok so on sd cards there's a slider on the side of it. this has an arrow (usually pointing down) that says lock next to it. make sure the slider isn't on the side that the arrow points to.
hope this helps ;-)
Apr 04, 2009 | Sanyo Xacti S650 Digital Camera
Memory Card Locked
Do you have a computer that will read the "memoery cards"? Try reading the cards. If there is nothing on the card you still should get a message telling you the status. Check the setup of the camera. Some cameras allow you to lock the memory card from setup memu. You might also need to "format" the card before you use them.
Jul 17, 2007 | Casio QV-R41 Digital Camera
Canon PowerShot A480 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
