How do i know it is charging?
Nothing pops up on my screan when I plug it in. Does the red light on the bottom of it mean that it is charging?
  • 684 Answers
Yes ur right when the red light turns green it states that it is charged
Posted on Aug 03, 2008
I have VIBE bluetooth keyboard for iPad mini ( VE 1089) and can't find ON switch
yes the red charge light will only stay lit for just a little bit... then turn it on by pressing down above the words written "charge". You should be pressing and holding down on a dial with three semi circles above it (as szuravic stated). Press and hold down until you get the bluetooth and power button lit on blue. Then go to your settings and bluetooth.... "bluetooth keyboard" should pop up. Click on it and then it will ask you to enter a 4 digit code on your keyboard followed by the return key. Soon after you should be "connected". If you are fully charged (first time plugged in should be 12 hours.. then after 4 hours) then you can unplug. Hope that's helpful!!
Feb 05, 2013 | Apple Ipad I-pad
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
Jan 28, 2011 | Samsung L200 Digital Camera
Just got a swagger and it wont keep charge. it shuts off in 10 min. what do I do? Also there is no screan how do I know if its charged right?
you have to make sure the player is off when ur charging it. or you can listen to it while its charging to make sure its not playing and charging at the same time. i had the same problem too. so just keep the ear phones plugged in and make sure its not playing while charging. and keep it turned off while charging. and you should be good. it will them play for like 1 to 2 hours. you might be thinking how can you turn it off and it still charges. but once the red light is on that means the computer regonizes it and its charging. good luck. facebook.com/kedisha queen-king
Dec 12, 2010 | Sakar MP3 Player
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
My blackjack 2 blinks yellow when i plug in the charger. it wont charge. theres nothing wrong with the phone that i can tell and when i checked the white dot it was red but it never got wet. its working...
when that white dot is red it means moisture of some sort got to the battery and mean the battery the damaged the light means the battery is charging abnormally so the best thing is ti get a new battery try ebay they are cheap hope this was helpful:)
Oct 19, 2009 | Samsung BlackJack II Smartphone
Red LED light?????
Nothing, that just means it is charging, when it goes off, it is fully charged
Jun 11, 2009 | Nintendo DS Lite
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Problem with my zen s screan
try to reset by holding down play and pressing reset
if that doesn't work try
holding down reset and play with battery disconnected
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
 Grubhead
Grubhead
