I have a Epson stylus the print has white lines on the letters as well as the photos. i have cleaned done head cleaning several times alignment no use it still prints the same
  • 24 Answers
It seems that the print head is clogged.
You can choose to live with it by print at slowest speed (best photo or things like that) Or you may try to fix, however, it requires some skills.
A. USING ALCOHOL
1. Check if what print head was clogged: Print a test page. 2. Look at the test page, identify incomplete lines. what are there colors? For instant, blue line: clogged on blue head 3. Remove the ink tanks, and pump alcohol through the clogged print head 4. Do head cleaning to see if it works
If it does not work, try B method. Please only do this if you have experience on disassemble a printer, or you have nothing to lose, because incorrect handling parts from printers will kill it forever.
B. DIPPING THE PRINT HEAD IN BOILING WATER
1. Remove the ink tanks,. 2. Remove all the cables connect to cartridge 3. Remove the cartridge 4. Boil some pure water ( Aquafina of Pepsi is the best) until small bubbles appear 5. Dip the head of cartridge ONLY in boiling water for 2 minutes. 6. Put all things together.
Posted on Mar 26, 2011
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
Horizontal lines in photos
Do head cleaning. Print at best photo quality.
May 04, 2010 | Epson Stylus 1400 InkJet Photo Printer
Hi, my Epson 2100 is printing with faint lines at regular intervals right across the page. I've done various alignment tests and cleaning tests but can't seem to clear the lines. Any advice much...
Are your alignment tests show good results? If they are, try head cleaning 3 consecutive times without printing nozzle checks. After 3 head cleanings do the nozzle check. If problem persists try printing at BEST PHOTO or whatever is the slowest print setting for your printer. Good luck!
Jan 14, 2010 | Epson Stylus Photo 2100 InkJet Printer
My epson stylus photo printer is printing a black vertical line in all my prints. I have done the head cleaning and print head alignment several times. Is there anything else I can do?
black vertical lines on the printout comes due to some reasons.
1) if the black cartridge is near to its end it will give black lines instead of proper printing.
the cartridges gets over many times due to head cleaning and deep cleaning.in 3-4 cleanings cartridge gets over.in one cleaning 4 ml of ink gets puled out of cartridge.the whole quantity of cartridge is near to 25 ml.
but if the cartridge is full then the problem is of cartridge head .the head is the part in which you insert the cartridges if the head is got blocked internally to its holes from where ink comes out.then there are two methods to clean the head one is head cleaning which you did.the other is removing the head by disassembling the printer and then cleaning the head manually with isoprophyll liquid.but its a time consuming and tough job.a local printer repair center will be advisable,
and in some cases it has seen that cartridge gets air pressure problem inside and due to that it leaks inside the printer so replacing that cartridge solves the problem.also many times the cartridge gets leaked and that leaked ink gets collected and stuck up on the roller of the printer from where paper passes so the strips of ink gets printed on the paper.in this case no head cleaning but cleaning the internal roller of the printer with tissue paper helps.the procedure is called servicing.that can also be done at local printer repair center.or you can do it manually by using tissue paper.but to service whole printer it needs to be disassemble.
check out his option.thanks.
Nov 20, 2009 | Epson Stylus Photo 1290 InkJet Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Color is printing w/ lines and I have attempted Alignment
when is the last time you changed your color ink cartridge?
that is what it sounds like to me if you have already did an alignment and cleaned them
May 02, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
311 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
