How do you flash program a ubnt nano 5 out side long distance WiFi system device
  • allan e milton Mar 26, 2011
    thanks so very very much
    Allan
  • 12,061 Answers
To flash a device such as this you will need to first find a manual, so I have given you links below..
www.ubnt.com/downloads/ns5_datasheet.pdf
Manual above.
www.ubnt.com/nanostation
help site above..
http://www.ubnt.com/forum/showthread.php?t=19795
Now, above, I believe at the above address you will be show how and what to do...
basically It's get the firmware using a browser etc, navigate to "it's address" and upload the firmware.
Posted on Mar 26, 2011
Note 2 wifi weak wifi signls. it works only if i go near to router distance between 3 meter
Bad router or it may be the wifi card in your device? I have a router that the wife's laptop cannot connect to very welll from 18 metres away. The guy down the road can logon to my network from 40 meters distance.
Maybe it is not the router.
Try replacing it with a newer model, the lifespan of a router is probably about 2-3 years before they start degrading. Check reviews for recommendations as to which has the best signal strength/range
Jun 11, 2015 | Computers & Internet
To do with Lock on.Air combat Simulation. whilst trying to install same, I keep on getting a message, saying.Abnormal Program Termination. no idea how to get to grips with this, has there is no other...
A method for warning abnormal connection between two bluetooth devices allows a user to adjust a distance between two connected bluetooth devices and to take an average obtained from several quality values read at that distance as a comparison value. Thereafter, a CPU of any one of the devices gets link quality value periodically by a host controller interface (HCI) command. The CPU will send out a warning message to mention the user of the bluetooth device when the quality value is lower than the comparison value, i.e. the connection is abnormal. And then, the user can handle it immediately, for example, pulls the two devices closer to lower the probability of the connection termination. The invention can reach the abnormal connection warning requirements for different users, and allows different users to have abnormal connection warning establishment for different distances.
An onboard device abnormal connection notification system is provided with: onboard devices (3a, 3b) which is connected to an in-vehicle network (5); a monitor means (1) which is connected to the in-vehicle network (5) for monitoring an abnormality in the state of connection between the onboard devices (3a, 3b) and the in-vehicle network (5); and a notification means (2) which is connected to the in-vehicle network (5) to notify an abnormality in connection of the onboard device (3a, 3b) based on a demand from the monitor means (1).
Jul 03, 2008 | Computers & Internet
Windows 8 keeps losing WiFi config
You can test it with an external wifi adapter. I use Edimax nano USB WiFi adapter (it cost around $15) and it has its own drivers and applications. Please don't forget to disable your internal wifi adapter after installing the external wifi adapter.
Feb 27, 2014 | Microsoft Computers & Internet
Isnt showing wifi set up
The WiFi has to be on. to get to the main programming, press fan & the up arrow @ the same time for about 5 seconds. Now that you are in the programming mode, you need to scroll through to, I believe level 39 and turn it ON. This will enable the WiFi. Then press done to get out of programming mode. Your thermostat should start searching now as long as there is WiFi to connect to. Then you need to register the stat.
Nov 30, 2013 | Honeywell RTH8580WF WiFi Thermostat
Wifi connection
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel.
2. Analogue video senders used to send audio and video to other TVs in the home.
3. Microwave ovens emit interference in the 2.4GHz band.
4. Wireless speakers and console controllers can cause interference with the wireless router.
5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem.
6. Power cables located near the wireless router can cause dropouts and speed reduction.
7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router.
8. Depending upon the location of large mirrors will reflect wireless signal away your computer.
9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances.
10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
May 13, 2013 | Computers & Internet
My i pod is connect to my wi fi but will not connect to internet
Wifi allows connectivity for device to device as local area networks. Where connecting the ipod to the computer is a local area network. Also, the computer can use wifi to capture worl wide web connectivity of the internet. The computer requires to have subscription to an internet provider server to make wifi make full capacity observeble beyond device to devcie captures. It is possible to have local and networking across distance with the the wifi.
Feb 08, 2011 | Computers & Internet
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
Need driver for apple ipod 4g nano
Try to update USB driver. Do this
1. Right click My Computer(from Start or the desktop)
2. Select Manage
3. If you see Computer Management window, select Device Manager from the left side
4. On the right side, look for Universal Serial Bus Controllers
5. Expand it
6. Look for anything that says iPod, or USB Mass Storage Device, or even Unknown Device.
7. If you see anyone of these, right click it and UPDATE DRIVERS
Jan 19, 2010 | Apple iPod nano
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
